nope. none that i could think of. i know each truck runs a little different then another but thats a big difference between our trucks. same applies to how some trucks only make 12 psi stock and others hit 20 stock with no problems. it still irks me that some of you guys are hitting 28-30 psi with the same mods as me and i have to struggle mine to just tap 20 for a split second. if you blink you will miss it.
figure i have a cihp, full exhaust, intercooler, icp mod, fpr mod, ccv mod, intake, and after each shift i drop to 8-10 then a slow climb to normaly 15-17 but if i hold the gear manually to the rev limiter i can just tap 20psi before the limiter kicks in
well it might have a chip... without me knowing... or the idm mod... or better yet the idk mod lmao... but joe you sound about like me at pittling with your truck.. but i am gonna ask... is the ccv mod really worth it???
