.080 OS pistons, probably the type with .040 piston to deck clearance, rods will be known in a couple days, but most likely C1TE or ECZ. Rods were resized so they likely lost some length too. You can pretty much add it up: wrong rods, .072, piston deck heigt .040, resizing loss .007 (depending on how bad they were out of round). Then add in a .045 gasket, and wallah, flathead specs!
That low compression figure is with 69cc 113 heads
