stock 460 carb
stock 460 carb
Don't know if it was stock, but I have an Edelbrock #1411, 750 cfm that runs awesome. This is a little bigger than usual, but I run the truck hard towing so I want the extra power. Many guys run a 600cfm or 650 cfm. Great power and low end.
I like the edelbrock because of it's simplicity and performance. Bolted it on and started it up. Simple tuning, simple metering rod changes. If you want to run a high reving race truck, then Holly is the way to go.
You will also need a manifold if you change to 4bbl. I hear the Edelbrock manifolds are a great combo with the carb. Mine is the stock minifold.
Good luck.
Good luck.
77truck460
03-17-2015 11:07 AM
sonnyjfoster
06-19-2014 02:35 AM
9Volt
07-09-2002 06:57 AM
