Rusted Front Coil Spring Towers - Ford Truck Enthusiasts Forums
Old 01-06-2008, 06:11 AM
SiverFox SiverFox is offline
SiverFox is starting off with a positive reputation.
Question Rusted Front Coil Spring Towers
I have a 1995 f-150 4x4 4.9 5spd. The front coil spring towers are rusted through. This is the part of the frame that the coil spring and shock attaches too. It is part of the frame. What is the correct name for this part and can it be replaced? If so do you have a supplier?
Thanks.
Old 01-06-2008, 06:35 AM
alz alz is offline
alz is starting off with a positive reputation.
You have the correct name. Yes, they can be replaced. You will have to remove the rivots(drill, grinder, air chisel). Just replace with grade 8 hardware.
Also, be aware there is a brake hose that runs through the bracket. It is held tight with a spring clip(dealer only item).
BroncoGraveyard has replacement towers as well as your local dealer. My dealer was actually a little cheaper, but needed to special order parts. So, I got them from BroncoGraveyard as they are local to me, about $100 per side.
Might as well replace the rubber brake hose while you have it all apart for good measure.
Let me know if you have anymore questions.
Old 01-06-2008, 06:46 AM
Thanks ALZ for the quick reply. I'm not crazy about going to the dealer and never thought of the bronco graveyard. I'm going to look now.
Old 01-06-2008, 06:58 AM
Mr Jimi's Avatar
Mr Jimi Mr Jimi is offline
Mr Jimi is starting off with a positive reputation.
I have heard these called
shock towers
Jim
Old 01-06-2008, 07:02 AM
JLDickmon's Avatar
JLDickmon JLDickmon is offline
JLDickmon is starting off with a positive reputation.
or spring perches
anyway, Ford still produces them as a replacement part, and they're really not that overly hard to do..
a spring compressor would be a good tool to rent from NAPA or Auto Stoned...
Old 01-06-2008, 01:45 PM
alz alz is offline
Spring compressor not really needed on these trucks. Lift the truck by frame. Remove the shock and the axle should drop enough to remove the spring. You may have to put a little weight on it, but definitely enough room.
Old 01-06-2008, 06:59 PM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
No compressor needed. There was a post that this is no longer a dealer part. Bronco Graveyard had them . They r of the dual shock type.
Spring housing R EOTZ 5A306 E
R EOTZ 5A306 J
Old 01-07-2008, 08:35 AM
aj197816134 aj197816134 is offline
aj197816134 is starting off with a positive reputation.
They are available from dealers still. There was a post about a month ago that had alot of good discussion. My local FORD dealer was able to get them in 2 days I recall, maybe one. If they can only get the "dual shock" design they will work just fine, even if you have the single application.
If you need any help or pointers post or PM me.
Definetly replace the following:
Tower (duh)
Rubber brake Line
Shocks
USE GRADE 8 HARDWARE
Anything else you do, is up to your as you see fit, shouldnt take long at all
Old 05-25-2011, 05:18 PM
dirtyfordtruck dirtyfordtruck is offline
dirtyfordtruck is starting off with a positive reputation.
Just ordered a coil tower from my local ford dealer for $68 and tax for my 1995 F150 4wd. The coil tower is a special order part and will be delived in 2 days.
R EOTZ 5A306 J
Old 05-25-2011, 05:41 PM
bent-1 bent-1 is offline
bent-1 is starting off with a positive reputation.
Old 12-16-2013, 04:38 PM
dieselpower4x4 dieselpower4x4 is offline
dieselpower4x4 is starting off with a positive reputation.
answer to your question
Quote:
Thanks.
those are front coil mounts and you can order new ones from rockauto.com
Old 12-16-2013, 04:48 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
This thread is about five years old, gotta believe the replacement towers have been on long enough started to rust!
Old 12-16-2013, 04:55 PM
Thanks.
you can buy them mounts for less than 50 a side on rockauto as long as you truck is single shock.
Old 12-16-2013, 05:00 PM
broncoderek's Avatar
broncoderek broncoderek is offline
broncoderek is gaining momentum as a positive member of FTE.broncoderek is gaining momentum as a positive member of FTE.
If your truck is single shock and you buy a double shock tower, can you just buy two additional shocks without buying anything else (are two lower mounts already there from the factory?
It's 15 degrees and snowy here or else I'd go out with a flashlight and check myself!
Old 12-16-2013, 10:13 PM
You can use the double with a single last I knew you could only get the doubles from ford! No need to add shocks
Rusted Front Spring/Coil Tower Ford F150 David Brunsting 1997 - 2003 F150 4 01-05-2017 09:53 PM
Will 1980 shock towers fit on a 1979? Wolffman 1973 - 1979 F-100 & Larger F-Series Trucks 10 11-02-2015 09:24 AM
Spring Tower Question Crop Duster 1961 - 1966 F-100 & Larger F-Series Trucks 4 07-19-2015 02:06 PM
what size bolts? front shock towers to frame mounting. crossy 1987 - 1996 F150 & Larger F-Series Trucks 0 05-28-2014 12:13 AM
1991 ranger passenger/right side coil spring bucket/tower davidmoss1992 Ranger & B-Series 7 03-25-2014 01:00 PM
Tags
150, 1995, 4wd, 4x4, 95, bracket, coil, f150, ford, front, perch, replacement, replacing, rusted, spring, tower
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
