Rusted Front Coil Spring Towers - Page 2 - Ford Truck Enthusiasts Forums
Old 12-17-2013, 06:29 AM
broncoderek's Avatar
broncoderek broncoderek is offline
broncoderek is gaining momentum as a positive member of FTE.broncoderek is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by aj197816134 View Post
You can use the double with a single last I knew you could only get the doubles from ford! No need to add shocks
I wasn't clear... I meant to ask if you WANTED to go to quad shocks, is there a lower mount for the second shock if your truck came with singles from the factory?
Old 12-17-2013, 08:58 AM
warren561 warren561 is offline
warren561 is starting off with a positive reputation.
I think the P/N's are the same for 4x4 and 4x2 single shock option.
<style type="text/css"><!-- br {mso-data-placement:same-cell;} --></style><table dir="ltr" style="table-layout:fixed;font-size:13px;font-family:arial,sans,sans-serif;" cellpadding="0" cellspacing="0"><colgroup><col width="207"><col width="105"></colgroup><tbody><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:1px solid #ccc;border-bottom:1px solid #ccc;border-top:1px solid #ccc;border-left:1px solid #ccc;">Right Spring Tower</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:1px solid #ccc;border-bottom:1px solid #ccc;border-top:1px solid #ccc;">EOTZ-5A306-E</td></tr><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:1px solid #ccc;border-bottom:1px solid #ccc;border-left:1px solid #ccc;">Left Spring Tower</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:1px solid #ccc;border-bottom:1px solid #ccc;">E2TZ-5A306-J</td></tr></tbody></table>(These are the ones that I used on my 4x2 F150, ordered from tascaparts.com)
Old 12-17-2013, 12:10 PM
wfilkins47 wfilkins47 is offline
wfilkins47 is starting off with a positive reputation.
Quote:
The stud for the forward shock on each side is already there on my truck which has single shock towers, should be all you need is a nut.
Rusted Front Spring/Coil Tower Ford F150 David Brunsting 1997 - 2003 F150 4 01-05-2017 10:53 PM
Spring Tower Question Crop Duster 1961 - 1966 F-100 & Larger F-Series Trucks 4 07-19-2015 03:06 PM
what size bolts? front shock towers to frame mounting. crossy 1987 - 1996 F150 & Larger F-Series Trucks 0 05-28-2014 01:13 AM
1991 ranger passenger/right side coil spring bucket/tower davidmoss1992 Ranger & B-Series 7 03-25-2014 02:00 PM
94 F150 Front Coil Spring Issue 1994 f150 4x4 1987 - 1996 F150 & Larger F-Series Trucks 2 06-23-2012 09:50 PM
Tags
150, 1995, 4wd, 4x4, 95, bracket, coil, f150, ford, front, perch, replacement, replacing, rusted, spring, tower
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
