Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-06-2008, 01:51 AM
Louisville Joe is starting off with a positive reputation.
Bell Housing Bolt Patterns
Someone help me! I can't remember what the story was with 351C/351M/400 bell housing bolt patterns. Some would only bolt to Cruise-O-Matics, some were the same as Windsors? Thanks.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-06-2008, 08:38 AM
firstonraceday's Avatar
firstonraceday is starting off with a positive reputation.
The 351M/400 utilized in the trucks have the same bellhousing bolt pattern as the 429/460 (385 series). I believe the 351C had the smaller bolt pattern.
There were some earlier 400 engines that were bolted to the FMX transmission as well, if I'm not mistaken.
__________________
Jason
2005 F-150 XLT SuperCrew, 5.4 w/Auto, 3.55LS
1993 F-150 300 I-6 w/5-Speed (Traded for the above 8/6/2005)
1977 F-250 351M w/T-18 (Rebuilt at 315,000 Miles)
2008 Escape Limited w/3.0L V-6 (Wife's)
  #3 (permalink)
Old 01-06-2008, 08:39 AM
mustang81 is starting off with a positive reputation.
351M/400 same bolt patern as 429/460 exception is 400 installed in full-size '73 Ford with the fmx automatic transmission(code PHB-AD). It has the same pattern as the 351C.
  #4 (permalink)
Old 01-06-2008, 01:11 PM
trinogt is starting off with a positive reputation.
My 1977 Cougar has 351M, but it's original transmission was an FMX!?
After three FMX's, I swapped out to a C6. So, did the factory put a 1973 block in my '77? (I am far from the car to be able to read date codes...)
__________________
Mark in FL
restoretherepublic.com
  #5 (permalink)
Old 01-07-2008, 05:00 PM
acct21 is starting off with a positive reputation.
There were large pattern (351M/400/460) FMX bell housings, weren't there?
If not, you have a really rare bird... a small pattern 351M block, and a small housing C6.
I would guess you went from a large-housing FMX to a C6.
  #6 (permalink)
Old 01-07-2008, 09:03 PM
Come to think of it, I believe the FMX had a removable bell housing...
That's probably how it was done.
I read a 1980's article that rated transmissions of all types. The C6 had a great efficiency loss, but had the highest increase of efficiency when built with a shift kit. (not to mention they are tough
The last C6 started acting up within the first week... Took it back to the shop and they found that the steel vacuum line was pinched off somewhere. They installed a rubber hose from manifold T to the modulator and that fixed it.
__________________
Mark in FL
  #7 (permalink)
Old 01-07-2008, 10:12 PM
That is true, the FMX/Cruise-O-Matic did had a separate bell housing.
  #8 (permalink)
Old 01-08-2008, 12:17 AM
wasn't Cruise O Matic the name given to all 3 speed Ford autos during the era? The C6 in my 71 Torino was called Cruise O Matic, according to the report I got from Ford Archives...
I have seen very few articles on building an FMX, but I have read a couple... I don't think they are as strong as the C6/C4's, so maybe that's why they are not so common.
__________________
Mark in FL
  #9 (permalink)
Old 01-11-2008, 04:51 AM
Sorry, we always called the FMX's Cruise-O-Matics.
  #10 (permalink)
Old 01-19-2008, 01:04 AM
baddad457 is starting off with a positive reputation.
The MX/FMX came with at least three different bell housings---small block, FE big block and the 385 series big block bells. I have two small block bells and an FE bell. There was a small block bell patterned 400 block. These were snatched up long ago by the Pantera crowd.
  #11 (permalink)
Old 05-21-2008, 10:39 PM
relient3074 is starting off with a positive reputation.
Not all of them....
I've got a '73 small bell 400 in my '67 f100. Was gonna sell it and get a standard 400, but I decided to track down a small bell c6 instead.
  #12 (permalink)
Old 05-28-2008, 05:27 PM
Most early 80's E-series vans had 302's mated to small bell C6's. Should be pretty easy to find.
  #13 (permalink)
Old 05-28-2008, 07:14 PM
You'd think....
Quote:
I thought finding one would be easy too, but alas, it's been a pain. Part of it is these D**N gas prices. Makes it too expensive to ship one from out of state or go pick up the ones I have found. They are all out in the middle of BFE and my 'bump' would cost too much in gas to go get it. I found ONE that someone doesn't want too much $$$ for, but it needed too much $ in repairs to make worth buying.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
