Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-05-2008, 10:56 PM
redneckgrl88 is starting off with a positive reputation.
Exhaust smell
I have a 87 F250 with a 302. Every time I drive it I smell like exhaust. Doesn't matter how short or long the trip, but the longer the trip the stronger the smell when you get out. I found 1 loose manifold bolt and tightend it, but no difference. Any suggestions?
Thanks,
Charlene
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-06-2008, 03:41 AM
RangerPilot's Avatar
<-- Private Pilot
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
Is the exhaust stock? Can you hear a leak?
When bolts wind up loose like that manifold...things bend. On an '87, it's definetly reasonable to assume that gaskets have gone bad in the exhaust.
  #3 (permalink)
Old 01-06-2008, 10:37 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
I would bet that the gasket is shot. So you will probably have to replace that. I would also strongly suspect you need a catalytic converter. There is a good possibility that someone removed it in the past, and without it your truck will stink.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #4 (permalink)
Old 01-06-2008, 12:23 PM
Both cat's are still there. I think they might be plugged though.
  #5 (permalink)
Old 01-06-2008, 07:38 PM
Tedybear is gaining momentum as a positive member of FTE.
Any smells like rotten eggs from the exhaust? That's usually the warning sign of a bad cat. (and I'm not talking Morris the kitty here LOL)
Also as mentioned it's very possible the gasket's crap and will have to be replaced. One of the things I can suggest would be having an exhaust shop that has a free exhaust check? Put the truck in the air and check for exhaust leaks. Once done? You'll have an idea of where you stand with it. Unless you personally "See" anything they suggest? Take things with a grain of salt. Ask to be shown anything they find..Then of course--come back with the report and we'll help you all we can if you want to resolve this yourself.
S-
  #6 (permalink)
Old 01-07-2008, 05:50 PM
[quote=Tedybear]Any smells like rotten eggs from the exhaust? That's usually the warning sign of a bad cat. (and I'm not talking Morris the kitty here LOL)
No rotten egg smell. And you really can't smell it when driving, maybe faintly. Its mostly my cothes/hair that smell like it after driving.
  #7 (permalink)
Old 01-07-2008, 07:21 PM
Ehh...I'd still opt for one of the free exhaust checks and have them check for leaks just to be safe. Might be something simple like the seals on the door are not tight enough, and you're getting some air leaking in. Probably slightly more so when stopped and the fumes raise up a bit.
S-
  #8 (permalink)
Old 01-08-2008, 01:53 PM
Sponsor
A rotten egg smell is not normal failure for a converter, and I have never personally observed a vehicle that had a rotten egg smell. So Ford and Toyota models had issues with such a smell when low quality fuels were used that had a excessive sulpher content, and was a combination of the bad fuel and an experimental catalyst design. This problem did not take effect till '98.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
  #9 (permalink)
Old 01-08-2008, 06:36 PM
Quote:
I travel over 700 miles a week for my job. And I do wind up at times behind cars that flat out reak!!!!! of rotten eggs/sulfer type order.
Quote:
credit to Popular Mechanics. Outstanding artical regarding what the smells can mean for everyones car and trucks.
With the Mod's permission? I can post the link to the full story.
(5) SMELLS LIKE: ROTTEN EGGS
WHEN: Any time your engine is running.
THE CULPRIT: Hydrogen sulfide in the exhaust, which is produced by trace amounts of sulfur in gasoline. It's supposed to be converted to sulfur dioxide in your catalytic converter. This may be indicative of a fuel-injection problem, and can be cured by a sharp mechanic. But often it means a failed catalytic converter. The bad news: A new cat is expensive. The good news is it's probably covered under warranty. Check with your dealer.
  #10 (permalink)
Old 01-08-2008, 11:45 PM
um guys, the back and forth about a rotten egg smell that I don't have really isn't helping me.
  #11 (permalink)
Old 01-09-2008, 12:33 AM
godblessmud's Avatar
Jack Daniels if ya please
godblessmud is gaining momentum as a positive member of FTE.
Welcome to driving a real truck sweetheart...
I would start the truck cold then crawl under before things get to hot and listen for leaks, do this in a WELL VENTILATED area (outside!!!!!) and never stay under the truck for extended period of time (if you really wanna be safe, hold your breath and when its time to breath, roll out from under the truck and repeat.)
If you dont find anything in the pipes then the next suspect would be the manifold gaskets like mentioned about, with engine idling hold a peice of tissue paper all around the manifolds and see if it flutters AWAY from them at any time.
__________________
Howdy I'm Scott and I'm an adrenaline addict
1990 F150 4X4 XLT Lariat 302 5spd
2000 Ranger 4x2 XLT 244 cid
S_T_G_'_s m_i_n_i_o_n_s:
Public Relations/Recon Dept.
I drink from a cup called fear!
"Hold on tight cause its gunna be wilder than any 8 second ride"
  #12 (permalink)
Old 01-09-2008, 02:31 AM
<-- Private Pilot
Quote:
Originally Posted by godblessmud
...with engine idling hold a peice of tissue paper all around the manifolds and see if it flutters AWAY from them at any time.
Emphasis on the "if it flutters AWAY"...not ripples...
I've seen my share of idiots think they had leaky manifolds using this test because the fan was blowing the paper all around.
  #13 (permalink)
Old 01-09-2008, 07:39 AM
flowriteexhaust is starting off with a positive reputation.
You also might want to check the emission tube on the back of the engine, it goes from the back of one head to the back of the other and is very common to rot out and you probably wouldn't hear it at an idle. There also might be another emission tube that rots out between the 2 cats, it goes in on the top of the pipe, so you really have to go under and look for it
  #14 (permalink)
Old 01-09-2008, 07:40 AM
Sorry, hit the button twice
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
