Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-05-2008, 08:26 PM
jetpilot029 is starting off with a positive reputation.
Custom engine computer????
Just a general inquiry here. Hope someone has done this or knows how / what is needed.
I have a 1963 F100 project that now has a Ford 5.0HO (1994 Tbird) coupled to a GM 700R4. I have the original engine computer that came with the Tbird. Don't wish to use it as it requires chip changes, etc. I am looking for a more flexible solution that will control the engine and, if possible, the transmission.
Does anyone know of a engine computer solution which is easily programmable and can handle the trans?
thanks.
__________________
63 F100
302 - 2bbl
being rebuilt as we speak
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-05-2008, 09:35 PM
antony25 is starting off with a positive reputation.
The original computer should work fine unless the engine has had a cam change and the 700r4 can be equiped with a vacuum operated tcc lock up.
  #3 (permalink)
Old 01-06-2008, 01:22 AM
Antony25,
thanks for the reply. I agree, the original computer will work. It just will not do what I want it to do, enable changes w/o a chip change (ie PC or programmer support) and I would like to be able to control the shift points, etc for the 700r4.
any one else?
__________________
63 F100
302 - 2bbl
  #4 (permalink)
Old 01-06-2008, 10:43 AM
Ranger88Den is starting off with a positive reputation.
Don't know anything about electronics, but some people suggest MegaSquirt. Good luck with your search, Dave
  #5 (permalink)
Old 01-06-2008, 05:06 PM
Currently megasquirt only controls the engine but the megasquirt megashift should be out soon. Is your trans a 700r4 or a 4l60e? The 700 is all mechanical except for the torque converter lock up. The 4l60e is computer controlled.
  #6 (permalink)
Old 01-08-2008, 08:35 PM
BowlingSuperior is starting off with a positive reputation.
Quote:
For direct transmission control (4L60E), the GPIO board will be available in about 2 months. Lance on the MegaSquirt site is road-testing the transmission control code right now.
The GPIO board interfaces to a MegaSquirt MS2 version (or MicroSquirt) using CAN network - this communicates engine RPM, throttle position, etc to the transmission controller, and during shifts the tranny controller can send a brief ignition retard command to the MegaSquirt.
- Bruce
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
