1987 to 1996 Tech info Misc Posts
This will be a list of links to FAQ's and info for our trucks. Please read only and do not post. If you want to add info please put it in the stick thread suggestion thread. We will try to get this thread stuck.
ELECTRICAL
Spark plug wire routing
Interior Fuse Panel Layout 1
Interior/Engine-compartment Fuse Panel Layout
95 351 Charging System Electical Diagram
95 351 Power Distribution Electrical Diagram
intermittent wiper(no cost fix)
Checking OBDI codes (EEC-IV)
TRANSMISSION
E4OD Electronic Components
Recognizing your transmission by code
Recognizing your transmission by bolt pattern
Torque Converter Clutch Lockup Switch
E4OD Torque converter removal/replacement:
Diagram
Removal Instructions 1
Removal Instructions 2
Replacement Instructions
BRAKES
heres how to do a brakeline
https://www.ford-trucks.com/forums/6...-how-tough.html
Front disc brake replacement (including auto hub dissembly)
AUTO HUBS
Auto hub exploded 1
Auto hub exploded 2
ENGINE AND RELATED COMPONENTS
Power specs in 95
IAC Valve Removal
Replacing the rear main seal (5.0/5.8 with E4OD): Instructions
Diagram 1
Diagram 2
electrical fan interchange! not sure if this is the right one to put up but its has pics.
https://www.ford-trucks.com/forums/6...ectro-fied.html
GENERAL MECHANICAL INFO
leaf spring shackles how to
also spring shackles
92-96 Coil Spring Specs
fuel tank sizes
on tank filling the other tank
clock spring replacement pictures
thank you ladyfire 3374
airbag code32 and clockspring replacement
BODY PARTS
interchangable doors
https://www.ford-trucks.com/forums/673298-door-swap.html
tailgate interchange
RADIO RELATED
87-91 radio removal
Tips for installing Sirius satellite radio
GENERAL INFO
<TABLE><TBODY><TR><TD vAlign=top width="100%">gear ratio & tire sizes:
http://4lo.com/calc/geartable.htm </TD></TR></TBODY></TABLE>
a quicker search for forums (post #11)
Thank you federic!
<TABLE><TBODY><TR><TD vAlign=top width="100%">I want to thank everyone who contributed especially ameritaz3038.
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
ELECTRICAL
TRANSMISSION
Diagram
BRAKES
AUTO HUBS
Auto hub exploded 1
Auto hub exploded 2
Power specs in 95
IAC Valve Removal
Diagram 1
Diagram 2
fuel tank sizes
BODY PARTS
RADIO RELATED
87-91 radio removal
GENERAL INFO
Thank you federic!
Robert, you're awesome for putting it all together. But I do think that it needs to be organized a bit, maybe into sections like Electrical, Transmission, Engine, Misc Procedures, etc etc. Some formatting would also make it easier to read such as bolded text and colors etc. We'll play it by ear.
I'll orginize it better tomorrow. The super mods said that it wouldnt be a problem. I'll also get them to delete all of these extra posts. I'll try diffrent colors also.
These are the posts removed from your sticky thread above. Everyone has done a great job on it, especially Rob for organizing it. Please refer to the thread below for discussion or additions you would like to see made to the sticky:
https://www.ford-trucks.com/forums/6...ggestions.html
Great job!
Great job!
houseofdiesel
17
07-21-2016 05:18 PM
