radiator drain plug on 2000 ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-05-2008, 12:59 PM
freqman freqman is offline
freqman is starting off with a positive reputation.
Howdy All,
I'm new to this site and to my Ford Ranger, and I wanted to know if you guys could assist me with my issue? I recently took my ranger to a Jiffy Lube to get an oil change and the attendant informed me that my antifreeze was brownish color and need to be changed, however they wanted $80.00 to do the service. Of course, I declined and now I want to do it myself, however I don't know where the drain plug is located. I looke under the radiator and spotted a whited colored plastic looking nut on the passenger side of the radiator. There was also a nipple under it that resembled a grease fitting. Could this be it??? Or is it somewher else?? Any advise would be greatly appreciated!
Thanks in advance,
Freqman
Old 01-05-2008, 02:09 PM
livinezy livinezy is offline
livinezy is starting off with a positive reputation.
That' it. You found it. I went through the same thing with mine the first time I flushed the system.
Old 01-06-2008, 11:27 AM
livinezy,
Thanx a million!!!
Old 01-06-2008, 01:01 PM
PW01 PW01 is offline
PW01 is starting off with a positive reputation.
Slide a piece of 1/8" rubber tubing over the "nipple" and drain it right into your container
Old 10-27-2011, 07:24 AM
kullamon kullamon is offline
kullamon is starting off with a positive reputation.
I busted my nut!!!
Read some threads there are some ranger models where the plastic bolt does not come all the way out. Is that true for a 2000?
If it can come all the way out my plans are to use locking needle nose pliers to get it out. If not an easy out. Or some rigged way.
My guess is go to an auto store and get a new one. Is it just a plastic bolt for like 5 bucks or do I need any other parts ling a new o-ring etc?
Let me know before I cause more problems than what I already got.
Old 10-27-2011, 08:25 PM
Rackster's Avatar
Rackster Rackster is offline
Rackster is starting off with a positive reputation.
Busted nut
Yes, the white nut is loosened to drain the radiator. I did as noted above: attached tubing to drain the radiator straight into containers. When tightening the nut after draining, I broke it like Kullamon. I think that I got a little overzealous using a wrench to tighten the nut (too much advantage). Be careful when retightening.
To get the broken nut out, I used a hex wrench that fit into the remaining nut stem (the threads essentially). I was lucky enought to back it out, redrain the radiator, and install a new replacement plug I picked up at Advance. The replacement design is better: turns in by hand and avoid the tendancy to overtighten (until it snaps!!).
Good luck fellas.
Kevin
Draining ALL coolant from Aerostar? DMTR Aerostar 31 01-31-2014 07:31 PM
screwed up my coolant flush, what would you do? hubler13f 6.0L Power Stroke Diesel 21 03-27-2010 08:15 PM
Drain Radiator afsigma21 Expedition & Navigator 7 04-09-2008 12:33 PM
Broke the radiator drain plug. Any Ideas counie Ranger & B-Series 10 11-10-2006 10:40 PM
Where's the radiator drain plug on my '97 Expedition? wavinwayne Expedition & Navigator 4 06-07-2005 01:14 PM
Tags
200, 2000, 4x4, at, drain, draining, f150, ford, location, plug, radaitor, radiator, radiatordrain, ranger, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
