Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-05-2008, 03:21 AM
73azbronco is starting off with a positive reputation.
Factory quality elec wire and connectors
Anyone have a source for factory quality wire and connectors? You know, wire that will hold up like original and good connectors, not those crimp on things from Checker (although those have a place and time for use). I used some stuf from NAPA but it rotted in 6 months... Tie wraps disintigrated in three months of Az heat...
I can make my own harness, I just need to find good wire and connectors.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-05-2008, 09:52 AM
dodmort's Avatar
dodmort is starting off with a positive reputation.
have you tried the "posi-locks" connectors.
expensive but sure are the answer in my case.
work well even wet.
5th year into a custom 69 f250 no failures and the have their place in my EB too.
no problems in my heat but not as hot here as AZ.
  #3 (permalink)
Old 01-05-2008, 01:34 PM
Thanks, I think Posilocks are OK for one wire splicing, I'm talking 2 to 6 wire connectors. Anyone? Thanks
  #4 (permalink)
Old 01-05-2008, 04:48 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
The best option that I've ever used for multi terminal connectors are GM WeatherPack. You can get them with pigails to solder or crimp on, or they come in kits with terminals, seals and connectors.
I've used Napa's Solder Seal, heat shrink connectors and they are pretty decent quality. They also have a crimp and seal connector that works pretty good too.
Actually, a standard crimp connector should have a better lifespan in the AZ heat because of the low humidity. In my experiences, corrosion causes a lot more connector failures than heat.
If you are using quality terminals and zip ties, they should last quite a long time. I've used 1000's of both subjected to under hood temperatures nearing 300 deg F + with minimal problems.
My pickup still has all of the cheap connectors on it that lived through 4 years of AZ heat. And that was almost 15 years ago. Looking at the snow on the ground and falling outside, kinda wish I was there about now
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
