reprogramming keyless door combination 2002 ford expedition - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 01-04-2008, 10:22 PM
mcjohnston4 mcjohnston4 is offline
mcjohnston4 is starting off with a positive reputation.
Smile reprogramming keyless door combination 2002 ford expedition
How do I reset the combination on my keyless door lock for a 2002 ford expedition? Thank you for any help at all. Mcj
Old 01-05-2008, 06:58 PM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputation
Moved from '09 F150 forum.
Welcome and thanks for joining us at FTE!
Old 01-05-2008, 09:50 PM
xxx609 xxx609 is offline
xxx609 is starting off with a positive reputation.
No owner's manual?? Do you know the factory code for the keypad?? If not, look for a large white label on a module under the dashboard slightly above the brake pedal; the five digits on that label are your factory code. I can walk you thru the process to re-program once you have the five digit factory code. Step 1: punch-in the factory code. Step 2: Punch the 1/2 pad within 5 seconds. Step 3: Enter your new five-digit code (each digit within 5 seconds). When the keypad illumination goes off, you're done. That's all there is to it!!! Let me know if that works for you.
Old 01-05-2008, 11:12 PM
Red face reprogramming keyless entry door combination
Thank you so much. I tried it and it didn't work, but it could be an electrical problem. I also have no inside lights when the car door opens and when I hit unlock at night none of the inside lights come on. Someone installed a cd player and I think they crossed wires some place that has caused some electrical things. I don't know whether to try to repair it without causing a more serious electrical problem, so at this point, I have left it alone. I was able to program the fob to open the doors, but have already locked myself out once with both fobs in the car. (Brilliant, right?) Anyway, I would love to be able to use the luxury of the door combination. I do appreciate your help. Also, maybe I used the wrong number. There are quite a lot of different letter and number sequence on the sticker. Only one was 5 digits in a row, so I used it. I will keep trying. Thanks again. MCJ
Power locks, no remote? Seahn 1999 to 2016 Super Duty 10 11-09-2011 03:13 PM
Do all 2002 F250 XLT's have keyless entry? GATRUCK Electrical Systems/Wiring 2 08-20-2006 10:22 PM
On putting Keypad door handles in non-keyless trucks. ChrisAdams 2004 - 2008 F150 4 09-02-2005 11:37 AM
Location of combination for Keyless entry pad. Innova 1997-2006 Expedition & Navigator 15 06-23-2005 02:09 AM
Keyless Entry Combination Code pmaldon988 Explorer, Sport Trac, Mountaineer & Aviator 2 07-15-2003 12:45 AM
Tags
2001, 2002, code, combination, combinations, door, expedition, f150, find, ford, keyless, keypad, lock, reprogram, reprogramming, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
