Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-04-2008, 09:16 PM
Black450 Black450 is offline
Black450 is starting off with a positive reputation.
Way to increase fuel mileage?
Came across this site while surfing the web. Sounds a bit sketchy, but I thought I'd let ya'll take a look. http://www.pureenergysystems.com/new...00069_Acetone/
  #2 (permalink)
Old 01-04-2008, 11:19 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 is starting off with a positive reputation.
Uh...
This has REALLY been beat to death...... Just do a search on this forum or go to the TDIclub forum and search for it. Just about everybody diesel has tried it. Some say it does something, some say it doesn't. Everyone argues. It's sort of like an oil thread. There has been no REAL scientific studies done. all you'll find is hype and testimonial "evidence"
__________________
1955 F-600 // D I S C L A I M E R: No animals were injured while test driving my F-600 except the ones I RAN OVER INTENTIONALLY!!! (RESISTANCE IS FUTILE) 73 de Rick
  #3 (permalink)
Old 01-06-2008, 01:26 AM
IDMooseMan's Avatar
IDMooseMan IDMooseMan is offline
IDMooseMan is gaining momentum as a positive member of FTE. IDMooseMan is gaining momentum as a positive member of FTE.
I'm a firm believer in, "if it sounds too good to be true, it probably is", and that has proven correct more than once.
I drive an older diesel truck. I averaged around 15.75 - 16.25 mpg combined city/highway when not towing. I checked my Fuel Pressure Regulator (FPR) pressure reading. It was low, so I shimmed it with a BB and cleaned the screen. That brought the pressure into the "normal" range of approximately 70 psi. I also started using a product called Diesel Kleen. I ran two tanks (about 35 gallons) and began tracking mileage again.
I took the average of four tanks (about 70 gallons) and was amazed. I was consistently averaged 17.25 mpg.
The Diesel Kleen helps clean out the fuel lines and injectors. Bringing the FPR back into spec helped alot. Throttle response was quicker and smoother. I didn't need to "get on it" as much when entering the freeway.
What this tells me, IMHO, is that properly maintaining your vehicle's systems and driving responsibly is the best way to go. Gas or Diesel, if your vehicle is not maintained on a regular basis, no "gadget" is going to cure the problem.
__________________
Craig "IDMooseMan" Peters
1997 F-350 XLT 4x4 Crew Cab Long Bed E4OD 4.10:1, 1991 Wilderness 24M
USAF SSgt 1983 - 1992, NAHC Life Member, Member: NRA and Good Sam
Homedale Rod and Gun Club Membership Committee Chairman, 1/1/2007 - 12/31/2009
To those that have served, Thank You. To those that haven't served, You're Welcome.
  #4 (permalink)
Old 01-06-2008, 03:08 PM
07psdrookie 07psdrookie is offline
07psdrookie is starting off with a positive reputation.
I use the grey bottle in the spring/summer months and the white in winter/fall. Overall seen about a .5 mpg gain (hand calculated and lie-o-meter)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
