top chop - Ford Truck Enthusiasts Forums
top chop
Old 01-04-2008, 10:10 PM
vintage56's Avatar
vintage56 vintage56 is offline
vintage56 is starting off with a positive reputation.
top chop
kind of taking a straw poll.
I hooked RUSTY50F1 up with a spare cab for a top chop. but I've always been a side line fan of laying pillars back and in with relief cuts.
there's a thread on HAMB ( http://www.jalopyjournal.com/forum/s...d.php?t=233070 ) that has Tex Smith's
I've also heard of guys cutting the roof in quarters with the cut lines front to back in the middle of the roof and side to side thru the middle of the door window openings and across the roof and filled in with donor roof section...
what are the experiences of the experienced choppers?
JML
if this seems choppy, I'm typing as I entertain a 4 y/o boy, push laundry thru and serve up dinner. mom's not feeling well.
Old 01-04-2008, 11:11 PM
427SOHC's Avatar
427SOHC 427SOHC is offline
427SOHC is starting off with a positive reputation.
Check out the gallery Marz-68 has posted, you may want to consider sending him an email, he shows his 68 with the top chopped and being rewelded.
Old 01-04-2008, 11:57 PM
CharlieLed's Avatar
CharlieLed CharlieLed is online now
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
I am a veteran of the 2005 & 2007 HAMB Chops so I have a little experience with chops. The technique used is determined by the end result desired. In addition to the unmolested 54 & 56 F100s, I have a 35 Chevy and a 50 Merc that will both be chopped soon. On the Merc I like the slanted B pillars so the roof will slide forward and the A pillars remain at their original angle. I have never been a fan of laying the windshield back but on some cars it does look good. This is what I call the Lake Dragster look. I have a DVD video of Ron Covell chopping the top on a 53 Stude PU, this is a great video if you get a chance to buy/watch it. Ron sectioned the top so that he could lower the top without changing the design of the rear window or the windshield (A pillars)...
Old 01-05-2008, 12:00 AM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Pretty much what the Ron Covell video shows.
JML
From what I know, the quartering of the roof to keep everything angled correctly involves laying a big piece of sheet metal over the top to cover the gaps.....done on an English Wheel. There was a 3 part article in Street Rodder a couple years ago that showed this way of doing it.
Old 01-05-2008, 12:27 AM
RUSTY50F1's Avatar
RUSTY50F1 RUSTY50F1 is offline
RUSTY50F1 is starting off with a positive reputation.
I think pulling the post back on a 48-51 makes the nose look to long. I'll leave mine straight and cut the roof from door to door, and pull the post toward each other a 1/2 inch. then put a strip back in the middle. The back window will be mail slot. About 5" tall in the middle. That's taking out 5" of the top. Plus this way you don't have to pull the door post back.
53 chop top classicrat52 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 05-17-2015 06:46 PM
Pointless van questions from a truck guy BruteFord 1968-2013 Full Size Vans 3 07-29-2014 09:28 PM
Help me chop my top please Leroy_J 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 10-21-2012 07:10 AM
Have you seen this? Top chop elgemcdlf 1967 - 1972 F-100 & Larger F-Series Trucks 15 11-14-2011 01:15 PM
Ax et all - Chop top Question ferguson777 1948 - 1956 F1, F100 & Larger F-Series Trucks 56 11-15-2006 06:42 PM
Tags
1948, 1950, 1977, 50, 53, chop, choping, chopped, chopping, f1, f100, ford, top, truck, videos
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
