Do casting numbers a CJ make?
Old 11-04-2002, 07:12 AM
jimlj's Avatar
jimlj
jimlj is offline
I recently bought a running engine with a D1VE block and C9VE-A heads. Looking in a book I have it lists those casting #'s as the block and heads used in the CJ and SCJ engines. Is that all it takes to make a CJ, or are there other internal parts involved. Did I luck out getting a good running engine or did I really luck out and get a rare good running engine? I have not pulled the oil pan or measured the stroke, so I have no idea if it's a 460 or 429. Any guess what this may be worth? TIA
Jim
Old 11-04-2002, 07:59 AM
georgedavila's Avatar
georgedavila
georgedavila is offline
The heads are not CJ/SCJ. Only casting number for those heads was DOOE-R. CJ/SCJ blocks were DOVE and DIVE-AA.
Old 11-05-2002, 07:31 AM
jimlj's Avatar
jimlj
jimlj is offline
George, thanks for the reply. I appreciate your input. Is there any source that details the casting #'s on the different 429/460 engines?
I bought Tom Monroe's book on rebuilding the 460 engines, and it lists 3 or 4 heads used on the CJ engines through the years, and several blocks. He states that that comes from the best information that he had avalable. Is sounds like there may be some confusion on his part even. It's not that I doubt your reply, I am highly confused. I am just trying to learn more.
Old 11-05-2002, 08:14 AM
georgedavila
With the exceptions of CJ and PI heads and some block numbers, Monroe's book is an excellent reference, as are others. Easy way to define 385 casting numbers is to first take out the CJ/PI numbers.
'70/71 CJ and PI heads (no difference) are DOOE-R. '72-74 PI heads are D20E-AB.
'70/71 blocks with thick main bearing webs are DIVE-AA and DOVE (can't remember the last letter). Some were finish machined as 2-bolt mains, some 4-bolt. Some CJ/SCJ blocks also had CJ in the lifter valley, others didn't. All other '68-78 blocks, regardless of casting numbers, have standard webs.
Then use the first two digets of the casting number for year of manufacture for the rest.
C8 = '68
C9 = '69
DO = '70
DI = '71
D2 = '72
D3 = '73 up
I've heard there are D4s but haven't seen any
Crankshafts are 4U for the 429, 2Y for the 460. There are 3Y 460 cranks, but stay with the 2Y.
'68-'71 heads are small chambered with rail rockers, '72 (D2XX) stay away from due to open chamber, '73-78 D3 have the intake valve raised .100 with larger chambers and pedestal mounted rocker arm assembly. All, other than the CJ/PI and D2, will provide about the same results with extensive porting.
4-bolt blocks are scarce, and no longer that important unless you're a restorer. Several vendors now provide 4-bolt conversions for the 2-bolt thin-webbed blocks that will handle up to 900-1000hp. Beyond that, things start moving around and an aftermarket 4-bolt is required.
Old 11-10-2002, 09:35 PM
trinogt's Avatar
trinogt
trinogt is offline
So, what you are saying is my D1VE block could have 4 bolt mains? Is the D1VE block commonly found in 73-79 trucks? My truck is a 76, but I have no clue as to the originality of the engine. Heads are run-of-the-mill D3VE A2A.
Mark
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5362&.jpg
Ford started it; Ford will finish it!
Old 11-11-2002, 08:27 AM
georgedavila
It's a real long-shot that you have a 4-bolt, but stranger things have happened.
Old 11-12-2002, 10:33 AM
Fordzzzz77's Avatar
Fordzzzz77
Fordzzzz77 is offline
georgedavila....... DOVE-A is the other one your looking for. Never seen a DOVE-B or anyother combinations.
77 F250 Highboy 4X4
"The Money Pit"
"If it wasn't for Chevy's my tools would rust"
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=9893&.jpg
Old 11-12-2002, 10:57 AM
Fordzzzz77's Avatar
Fordzzzz77
marcs724
03-15-2013 06:11 PM
rfillion
09-21-2008 06:06 PM
jtgb428
02-05-2008 04:49 PM
Racemaster33
12-26-2006 07:27 AM
Wrencher
07-14-2001 09:16 PM
Quick Reply: Do casting numbers a CJ make?
