Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-04-2008, 09:49 PM
Broncboy86 is starting off with a positive reputation.
EFI questions
EFI swap. I just got my HO SD EFI on my 302 and I need to know how many O2 sensors do i need. i have long tube headers into single exhaust. also where can I buy the O2 wiring harness that plugs into the main computer harness. thanks for the help
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-05-2008, 12:53 AM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
The HO uses 2 O2 sensors. One in each manifold. Ideally, you want them as close to the stock location as possible to keep the computer happy. I mounted mine in the header collectors and have noticed no adverse affects.
Ford Racing used to sell an O2 harness, but I'm not sure if they would fit all of the HO harnesses 86-93, or just the MAF. I'm not sure if there is a difference. Never compared them. You may be able to search wrecking yards for a used one if you have the resources.
There is also RJM that makes complete harnesses. They may be able to put something together for you.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #3 (permalink)
Old 01-05-2008, 08:09 PM
thanks for the help jason.
so does anybody have one they would be willing to sell cuz all the ones ive found are for the maf motors and i dont know i that matters.
  #4 (permalink)
Old 01-06-2008, 01:11 AM
RCrawler's Avatar
I have a couple of spare harnesses. I will look and see if they have the O2 harnesses with them and let you know in a PM.
Jason
__________________
  #5 (permalink)
Old 01-06-2008, 10:52 PM
thanks man thats awesome
  #6 (permalink)
Old 01-10-2008, 10:56 PM
fordtrucksforever is starting off with a positive reputation.
I thought the O2 sensor plugged directly in to the main harnass. If you have the other sensors and injectors already wired in, the plugs should be there. The O2 sensors come with the wires and plugs, in several different lengths that should accomodate just about any conversion.
  #7 (permalink)
Old 01-13-2008, 12:10 AM
nope, they do plug right in. but the guy i bought it from unplugged it. I just made my own harness.
  #8 (permalink)
Old 01-13-2008, 06:33 PM
ok so new problem. I have everything wired in and Im not getting power to my fuel pump. I have power to the eec relay but no power to the fuel pump relay. If Im right the red wire coming from the green connector near the computer, is the power to the coil side of the relay and the tan/light green wires are the ground. so then i attach 12v hot wire to the switched side and run the last wire to the fuel pump power. so when the key is turned of then the computer grounds the fuel pump relay through the two tan/light green wires causing the switch to contact and run the 12 v through to the fuel pump. but I am not getting any power. HELPPPPP. lol thanks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
