6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
driving 6spd thru city
Old 01-04-2008, 07:01 PM
Sn00ky's Avatar
Sn00ky
Sn00ky is offline
Kinda curious...
do most owners of the manual trannys "idle" about town, or keep in lower gears?
just kinda wondering because the truck (empty) gets about town in higher gears and low rpms pretty easily...so i am curious as to if anyone else take advantage of this in terms of mileage? i normally run around 1500rpm around town (30-50mph)
Old 01-04-2008, 07:06 PM
oltrucker's Avatar
oltrucker
oltrucker is offline
i run my 6.0 around town at 1000--1200 rpm. the rule is , if it will excelerate smoothly, your not lugging it. if it wont , you are lugging it. 1500 is ok too.
Old 01-04-2008, 07:10 PM
Sn00ky's Avatar
Sn00ky
Sn00ky is offline
yeah, that's kinda what i am doin too....
and also, if i am doing that around for a while....then i'll give it a good run, get a bit of boost on the go, just to "clear throat"....hahah...more for fun that anything thou!
Old 01-06-2008, 05:31 PM
oltrucker's Avatar
oltrucker
just another way to waste $3.60 a gal fuel.
Old 01-06-2008, 06:12 PM
kawtiper's Avatar
kawtiper
kawtiper is offline
wow am I glad i dont live where you do. $3.60? ouch
Old 01-08-2008, 08:47 AM
the Goat's Avatar
the Goat
the Goat is offline
V10 and 6-speed here.
When driving around town I use the highest gear possible. I also have a 4.30 rearend so I can get away with running in fourth or overdrive basically anytime I'm not accelerating or crusing at less then 30mph.
Also in stop and go traffic I sometimes leave it in granny low and let it crawl along. It will climb up hills at idle without a problem.
FordOwnerJoey
06-13-2016 12:54 PM
Krazee Matt
Texas Chapter
05-21-2016 01:27 PM
mdb0531
1999 to 2016 Super Duty
04-27-2016 10:34 AM
RSUPERDUTY
05-28-2010 09:38 PM
Quick Reply: driving 6spd thru city
