The worst smell???? - Ford Truck Enthusiasts Forums
The Next Generation For those ages 15-25.
The worst smell????
Old 01-04-2008, 04:37 PM
385seriesHemi 385seriesHemi is offline
385seriesHemi is gaining momentum as a positive member of FTE.
Thumbs down The worst smell????
What do you think the worst smell is when you are working on something? I think the oil inside the crankshaft main caps bolt holes when you are tearing down an engine is freakin' stinky!
Old 01-04-2008, 05:13 PM
oaskills oaskills is offline
oaskills is starting off with a positive reputation.
Definenitly the oil in the mains bolt holes. That stuff is nasty!
Old 01-04-2008, 07:32 PM
scrapyardking scrapyardking is offline
scrapyardking is gaining momentum as a positive member of FTE.
I was burning an axel apart the other day on a junk truck and I got some half burned old gear oil on my shirt, Thats the worst thing I can think of.
Old 01-05-2008, 02:00 AM
Old Rust Bucket Old Rust Bucket is offline
Old Rust Bucket is gaining momentum as a positive member of FTE.
Does if have to be truck related? If not I'd say working at the packing plant. That is a smell that as long as I live I shall never forget...
Old 01-05-2008, 12:24 PM
cdrmotorsports's Avatar
cdrmotorsports cdrmotorsports is offline
cdrmotorsports has a good reputation on FTE.cdrmotorsports has a good reputation on FTE.cdrmotorsports has a good reputation on FTE.
Gear or transfer case oil for sure. It is horrible.
Old 01-05-2008, 01:57 PM
JBradley500's Avatar
JBradley500 JBradley500 is offline
JBradley500 is starting off with a positive reputation.
a burning clutch or torching bushings to get them out....both make me cringe.
Old 01-05-2008, 03:53 PM
keyul's Avatar
keyul keyul is offline
keyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to all
I changed the gear oil in my 79's gear box a few months ago, I don't think it has been done since my dad had bought it near 20 years ago, very bad smell.
Old 01-07-2008, 12:55 AM
Old gas is another one once it sits for about 5-10 years it stats to smell.
Old 01-07-2008, 01:03 PM
skilife17's Avatar
skilife17 skilife17 is offline
skilife17 is starting off with a positive reputation.
I think the worst smell for vehicle is gear oil.
At work the worst smell is the yeast. I don't have to mix with it but it sure is foul smelling. Another one is vinegar, I used to work at a grocery store and if that spilled, it lingered through the store.
Old 01-12-2008, 05:54 PM
F250FarmBoy's Avatar
F250FarmBoy F250FarmBoy is offline
F250FarmBoy is starting off with a positive reputation.
Quote:
x2 Those linger on for quite awhile.
Old 01-12-2008, 06:14 PM
godblessmud godblessmud is offline
godblessmud is gaining momentum as a positive member of FTE.
Power steering fluid, stuff is rancid after 17 years...
Old 01-12-2008, 10:51 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Tractor Hy-Trans from sometime in the 80s. I had to run straight kerosene in the tranny the get the gunk out
Old 01-13-2008, 08:10 AM
Bobby82490's Avatar
Bobby82490 Bobby82490 is offline
Bobby82490 is gaining momentum as a positive member of FTE.
Burning clutch/brakes and gear oil.
At work we have this anti-bacteria stuff for the gas storage tanks, that we have to put in when they are empty. That stuff burns my nose a little.
Old 01-14-2008, 02:26 AM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
Gear oil...especially the old stuff.
Propane. I try to stand upwind whenever I fill the Forklift tanks...
Old 01-18-2008, 12:36 AM
fiftyfourdf100 fiftyfourdf100 is offline
fiftyfourdf100 is starting off with a positive reputation.
Burnt bearing grease
Burnt/used gear oil
A Chevy...unless its being smoked..then it smells gooooood
What's this supposed to smell like? pineconeford 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 02-02-2014 02:49 PM
Engine light on, Engine Bogging maxnoodle 2004 - 2008 F150 0 01-07-2008 08:07 AM
1998 F250 Heater Core Questions jahwa 1997 - 2003 F150 16 12-26-2006 11:52 AM
Coolent vapor coming in through heat vents motobub Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 05-01-2006 01:32 PM
Burning pad smell from rear brakes VIKING24 1999 to 2016 Super Duty 2 06-07-2005 10:12 PM
Tags
04, acid, bread, cab, duty, f150, ford, interior, ive, smell, super, truck, vinegar, worst, yeast
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
