Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-04-2008, 03:05 PM
Coppola is starting off with a positive reputation.
Question Water in Fuel light, and HFCM
The light started showing two weeks ago, I had both filters changed, but the light continues to show. I have tried to drain the HFCM, but have been unable to remove the plug. The 6mm hex wrench now looks like a pretzel. Has anyone else had this much trouble trying to remove the plug? Any Ideas?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-04-2008, 03:25 PM
run6.0run is starting off with a positive reputation.
First off the o-ring on that plug is the sealer. Not foot-lbs. of torque, so when you do get it out. Remember.... not so tight. To your question if its that hard to get out then I would say take a $100 bill to the dealer and buy a new cover and get a different plug (not oem) that allowes you to take it out by hand, it will also have a little hook that will keep it from falling out while draining. Sorry can remember the part#. Maybe somebody else will know it. As for the cover if you buy a new one look at how many threads hold the plug into the cover (1Thread, very easy to strip!!)
  #3 (permalink)
Old 01-04-2008, 06:23 PM
3000 FPS is starting off with a positive reputation.
I have drained mine several times and the plug always came out pretty easy. Is the hex stripped out because I have heard of that happening. If the hex is good try a good quality hex wrench that will not bend.
  #4 (permalink)
Old 01-04-2008, 06:54 PM
Coppola I did some more research and I have found that the plug can sometimes become frozen. Also if you live in cold weather and have not drained the HFCM it could have some gelling on the sensor causing the light to be on or else it just needs drained of water. run6.Orun is right the plug is held in by one thread and it has an oring for the seal. I believe the part number for the plug mentioned by run6.Orun is Ford Part # 6E7Z-9C082-A
  #5 (permalink)
Old 01-04-2008, 06:57 PM
moebdick's Avatar
moebdick is starting off with a positive reputation.
I'm guessing the plug and sensor are corroded, but you might be able to clean out the sensor compartment and get by temporarily until you get a new cover. Read this.
I see 3000 got you the Ford part number already. The International part number is 2589259C91 if you get it at an International dealer.
__________________
2004 F250 Lariat CC, 4X4 PSD
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
