Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-04-2008, 02:16 PM
banddr2 is starting off with a positive reputation.
Help! Radio Removal
I have a 2001 Escape. I bought the removal tools, I insert them, pull them slightly apart, the radio only slide out 3/4 inch and stops. I have tried prying any way possible, got rough with it, nothing. The side clips are clearing the frame, something is holding it in and I can't find it. Does anyone have ideas?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-10-2008, 10:24 AM
Ford43 is starting off with a positive reputation.
I had this same problem about a month ago. I have the 6cd changer in mine. I put the DIN tools in the slots and it stuck. One of two things you can do. Take off the dash face, be careful not to pull on the heater controls too hard after you remove the knobs.(learned this the hard way, I broke and knob and a heater control cable) Under the radio there is a track that is a brace for the radio. I took a small screwdiver and pryed lightly on the sides of a white clip that rides along this track. this loosened it up some. Make sure that the DIN tool is all the way in the slots until you hear it snap. Do not try and use a bent coathanger for the DIN removal tools(they worked in older vehicles, but do not work in the escape). The DIN removal tool is available at Wal-Mart for 3 bucks. This should let the radio slide out on the track. If you have any other questions about this feel free to post back and I will try and help. I assume you are going to get rid of the factory unit(best decision I made) The factory speakers in mine sound great with the aftermarket head unit. Good luck with it.....
__________________
Remember folks mash it to the floor until you hear it whining! It's a Ford!!
2002 Escape XLT
2005 500 SE
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
