The fuel pump you need is for a 6 cyl, the ones you are looking at are for V8s. They pop up on eBay. I also might have one, rebuilt, from when I had a couple of the flathead 6's. If you can't find one I can dig around and see if I still have it. The fuel pump was the same on the 1/2 ton and 1 ton 6 cylinders.
__________________
Gary-
Down to only one, a 1946 1/2 ton
Collector of anything related to 42-47 Ford Trucks
Do I need a glass bowl pump or a steel bowl pump? Do you have a Mac's catalog handy? The pumps don't seem to say for 6's, just for 8's and specific years...
The only glass bowl 6 cylinder specific pump listed is for 47-48? "47-48 with glass bowl, 6 cylinder cars with vaccym controlled distributor" Which is not me, I'm sure.
__________________
-There's no replacement for Displacement
I can't remember, but I think all the 6's I had, and the pump I have, might have been the glass bowl versions. I was just thinking though, do have the original '46 6 in that truck, the G series motor, or has it been swapped to the H series? G series has a crab type distributor, while the H uses a more modern looking distributor
__________________
Gary-
