Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-04-2008, 11:01 AM
Storm is gaining momentum as a positive member of FTE.
Air Intake
Ok... This is annoying.. I got the separating air filter crap going on with my donaldson system.. Some folks said to get the AFE Replacement filter that has the metal canister instead of the plastic on. It helps to keep it the seals from opening. We did the smoke test and all the smoke was being pulled into the intake
Anyone know if that filter is ok to us? I'll still have stock setup, just the filter will be in metal can instead of a plastic on.. I talked to Ford and they said that the intake isn't covered under my 100k warranty, not bout to pay arm and leg for another system..
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-04-2008, 11:54 AM
4x4Mark is starting off with a positive reputation.
Look under your emissions warranty, the induction system is covered there.
Mark
__________________
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP exhaust, Coolant Filter, FluidAmpr, Elite Regulated Return (55 psi), Airdog
Built: 11/03/03
  #3 (permalink)
Old 01-05-2008, 12:31 AM
randomhero1172 is gaining momentum as a positive member of FTE.randomhero1172 is gaining momentum as a positive member of FTE.
storm i think it really depends on who your dealer is and your diesel tech. A good tech will look at any problems and ask "does it have anything to do with mods?" if not - they should still hold your warranty valid. Of course there are the jerks who will see a small modification a void your whole warranty. Ex - if your fuel pump went and they decided to void your warrant because of the intake...obvious BS. I would talk to your diesel tech, not some suit in the dealership. GL!
__________________
- Joe
2002 f-250 CC long bed 7.3 PSD - 295,000mi: 6637, Zoodad, Foil Delete,Silverstar Ultras, CCV, 5" MKO Strait Pipe, Cab Lights, WW.
NEW!!!! - 1990 f-350 dually 7.3 IDI 12ft Alum. Boc. 197,000. A little shaky
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
