1987 to 1996 Tech info - Ford Truck Enthusiasts Forums
Closed Thread
Old 01-05-2008, 10:34 AM
rbloodhound's Avatar
rbloodhound rbloodhound is offline
rbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud of
This will be a list of links to FAQ's and info for our trucks. Please read only and do not post. If you want to add info please put it in the stick thread suggestion thread. We will try to get this thread stuck.
ELECTRICAL
Spark plug wire routing
intermittent wiper(no cost fix)
Checking OBDI codes (EEC-IV)
TRANSMISSION
Torque Converter Clutch Lockup Switch
BRAKES
heres how to do a brakeline
http://www.ford-trucks.com/forums/6...-how-tough.html
Front disc brake replacement (including auto hub dissembly)
electrical fan interchange! not sure if this is the right one to put up but its has pics.
http://www.ford-trucks.com/forums/6...ectro-fied.html
GENERAL MECHANICAL INFO
leaf spring shackles how to
also spring shackles
92-96 Coil Spring Specs
fuel tank sizes
on tank filling the other tank
clock spring replacement pictures
thank you ladyfire 3374
airbag code32 and clockspring replacement
BODY PARTS
interchangable doors
http://www.ford-trucks.com/forums/673298-door-swap.html
tailgate interchange
RADIO RELATED
87-91 radio removal
Tips for installing Sirius satellite radio
GENERAL INFO
<TABLE><TBODY><TR><TD vAlign=top width="100%">gear ratio & tire sizes:
http://4lo.com/calc/geartable.htm </TD></TR></TBODY></TABLE>
a quicker search for forums (post #11)
Thank you federic!
<TABLE><TBODY><TR><TD vAlign=top width="100%">I want to thank everyone who contributed especially ameritaz3038.
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
Manual Injector Cleaning - The How To Thread
http://www.ford-trucks.com/forums/10...to-thread.html
3G Alternator Swap: Should I think about doing one?
http://www.ford-trucks.com/forums/11...doing-one.html
Ford Steering Box Rebuild
http://www.ford-trucks.com/forums/10...x-rebuild.html
Ford Front End Rebuild and auto hubs replacement
http://www.ford-trucks.com/forums/11...l#post11243835
Ford Rear Drum Brakes
http://www.ford-trucks.com/forums/11...l#post11743946
Adding Cruise Control
http://www.ford-trucks.com/forums/11...e-control.html
Closed Thread
Crown Vic swap & lowering link dump Nudnik 1967 - 1972 F-100 & Larger F-Series Trucks 2 11-13-2013 09:34 AM
Manuals snd Reference Guides for the 6.0L - Must read for new owners bismic 6.0L Power Stroke Diesel 21 01-04-2012 08:32 AM
FAQ - Torque Specifications ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 01-15-2011 08:22 PM
1987 to 1996 Tech info Misc Posts rbloodhound 1987 - 1996 F150 & Larger F-Series Trucks 14 01-05-2008 04:45 PM
Tags
1987, 1996, 460, airbag, code32, f150, fix, ford, info, installing, main, rear, seal, tach, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
