Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
Closed Thread
  #1 (permalink)
Old 01-05-2008, 11:34 AM
rbloodhound's Avatar
rbloodhound rbloodhound is offline
Just another nut
rbloodhound is a splendid one to behold rbloodhound is a splendid one to behold rbloodhound is a splendid one to behold rbloodhound is a splendid one to behold rbloodhound is a splendid one to behold rbloodhound is a splendid one to behold rbloodhound is a splendid one to behold
This will be a list of links to FAQ's and info for our trucks. Please read only and do not post. If you want to add info please put it in the stick thread suggestion thread. We will try to get this thread stuck.
ELECTRICAL
Spark plug wire routing
Interior Fuse Panel Layout 1
Interior/Engine-compartment Fuse Panel Layout
95 351 Charging System Electical Diagram
95 351 Power Distribution Electrical Diagram
intermittent wiper(no cost fix)
Checking OBDI codes (EEC-IV)
TRANSMISSION
E4OD Electronic Components
Recognizing your transmission by code
Recognizing your transmission by bolt pattern
Torque Converter Clutch Lockup Switch
E4OD Torque converter removal/replacement:
Diagram
Removal Instructions 1
Removal Instructions 2
Replacement Instructions
BRAKES
heres how to do a brakeline
http://www.ford-trucks.com/forums/6...-how-tough.html
Front disc brake replacement (including auto hub dissembly)
AUTO HUBS
Auto hub exploded 1
Auto hub exploded 2
ENGINE AND RELATED COMPONENTS
Power specs in 95
IAC Valve Removal
Replacing the rear main seal (5.0/5.8 with E4OD): Instructions
Diagram 1
Diagram 2
electrical fan interchange! not sure if this is the right one to put up but its has pics.
http://www.ford-trucks.com/forums/6...ectro-fied.html
GENERAL MECHANICAL INFO
leaf spring shackles how to
also spring shackles
92-96 Coil Spring Specs
fuel tank sizes
on tank filling the other tank
clock spring replacement pictures
thank you ladyfire 3374
airbag code32 and clockspring replacement
BODY PARTS
interchangable doors
http://www.ford-trucks.com/forums/673298-door-swap.html
tailgate interchange
RADIO RELATED
87-91 radio removal
Tips for installing Sirius satellite radio
GENERAL INFO
gear ratio & tire sizes:
http://4lo.com/calc/geartable.htm
a quicker search for forums (post #11)
Thank you federic!
I want to thank everyone who contributed especially ameritaz3038.
__________________
Robert
Join the Louisiana Chapter, Click Here
04 F350 srw cc lwb 4x4 6.0 arp's, cat back, Innovative tuned
05 Excursion limited 4x4 6.0
51 F1 needs resto
LIFE TIME MEMBER OF NRA
Closed Thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
