Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-04-2008, 10:04 AM
2002 F-150 FX4 is starting off with a positive reputation.
3.8 V6 Starting problems
I'm trying to help out my buddy with his 3.8 V6. When its below 20 the engine has a hard time turning over. Thought it was the battery replaced it still having the same problem. Is it the alternator? or is it somthing else? It doesn't sound like its the starter.
If any one has an Idea what it might be?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-04-2008, 11:21 AM
BrianA's Avatar
BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.
You might want to do a voltage check on the battery just to be sure. It does sound like a low battery condition.
The alternator doesn't come into play when cranking. It just keeps the battery charged while driving. So, if the alternator is not charging the battery properly, then even the new battery might be weak.
Maybe try throwing a battery charger on it for a 1/2 hour before starting on a cold morning to see if that helps.
Also, what oil is he using? Heavier weight oils will get pretty thick on cold mornings and can lead to slow engine turn-over.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
Alabama Chapter Leader
  #3 (permalink)
Old 01-26-2008, 02:51 PM
tyc11388 is starting off with a positive reputation.
i agreeyou need to use the 5w20 recommended by ford
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
