coil spring question - Ford Truck Enthusiasts Forums
Old 01-04-2008, 09:53 AM
jae125 jae125 is offline
jae125 is starting off with a positive reputation.
I'm new to the group and have a question related to the application of coil springs...I've got a 95, 300 F150 4X4 and was wondering if it could get a little extra height in the front by repalcing the stock springs, whcih I've already got off because one broke.
I appreciate the detail provided by Road Rash, however I unfortunately don't exactly uderstand what it all means...also I read the thread by MSB71 however looking at his truck it has the 351 and I wasn't sure if the CC884S that he used, although it provided the increased height I want, maybe too much for my little 300.
Any help would be appreciated.
Jim
Old 01-04-2008, 10:02 AM
Skandocious's Avatar
Skandocious Skandocious is offline
Skandocious is gaining momentum as a positive member of FTE.Skandocious is gaining momentum as a positive member of FTE.
Welcome to the site Jim.
I'm not sure I understand your logic... You think your truck needs less lift because it has a smaller engine?? You're thinking because the engine is smaller and wouldn't compress the springs as much? I think the difference would be pretty negligible there. But yes, you can replace your springs with some taller ones to get some more height, but not too much before you need to start adding other things like radius arm drop brackets.
Old 01-04-2008, 06:49 PM
msb71's Avatar
msb71 msb71 is offline
msb71 is starting off with a positive reputation.
Take another look at the post by Road Rash, and use the unsprung height and ride height of the springs there are springs for a F-150 that give a higher ride height.
i got the CC844S's because it is a crew cab , and I tow a camper throughout the summer, which gives my truck more weight for a F-150.Have anymore questions feel free to ask. Good Luck
Mike
Old 01-05-2008, 11:11 AM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
If you broke 1 spring I bet just a new set of coils . Will raise the front aways . I used the F350 coils for years. Reguardless of motor I'd go with one of the taller coils at least.
I just took a set off a truck that looked fine 90000 Miles the new coils lifted front 1 1/2 . And that was after 4 weeks of install and some heavy hauling. They should have settled by then.
Good luck
Source for Mark VIII IRS Lowered Coil Springs? ralphhood3 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 06-03-2010 01:20 PM
75-79 4x4 Steering Box and tall springs? JimBoB77 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-22-2008 04:16 PM
Coil springs in 2000 Jim242002 1997 - 2003 F150 2 04-02-2007 01:58 PM
Front Coil Spring Height???? saros7 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-02-2005 06:59 AM
Virginia Chapter Tomcat7742 General Chapter Discussion 15 11-19-2004 02:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
