8X6.5 to 170mm rear hub change - Ford Truck Enthusiasts Forums
Old 01-03-2008, 08:07 PM
asltrfl's Avatar
asltrfl asltrfl is offline
asltrfl is starting off with a positive reputation.
I'm having trouble finding out if I can put 8X170mm rear hubs on my 86' 10.25" Sterling rear end.
The 86' 10.25" Sterling rear axle comes with 8X6.5" bolt pattern. I have installed a 2002 Dana 60F in the front with the newer 8X170mm bolt pattern. This kind of sucks. They changed bolt patterns in late 1999, so my question could be:
Will rear hubs from a 2000 and later Sterling 10.25 (or 10.5") fit on an 1986 Sterling 10.25" rear end. Of course part numbers are different due to the bolt pattern, so I am hoping one of you has some experience I can draw from. Thanks!!
Old 01-04-2008, 10:17 PM
asltrfl's Avatar
No takers? With the wealth of information here someone must have had or remember a similar condition. I've used the search option and cannot find any answers. Surely, someone has done this conversion or at least tried?
Old 01-05-2008, 02:12 PM
subs1000w subs1000w is offline
subs1000w is starting off with a positive reputation.
i have no idea but if i were in your shoes i would call a dealer and if they could not tell me i would order the parts and when they arrive compare and if there not the right parts i would return them
the other option is to get a rear from a 99+ and swap that in the rears are ussually a dime a dozen
Old 05-15-2012, 03:40 PM
cliffordingles's Avatar
cliffordingles cliffordingles is offline
cliffordingles is starting off with a positive reputation.
I'm tracking this tread is over 4 years old... But im trying to find info regarding the install of the later axles in the 80's truck's...
Are the later Superduty axles a bolt in for a truck like my 86' F250HD?
I think i read before the spring perches are not the same... Can anyone please throw in some input on the swap? Thank's!
OBS Dana 60 and super duty Dana 50/60 I terchsngability? HELP! parkerparkerm 1987 - 1996 F150 & Larger F-Series Trucks 4 07-17-2013 08:23 AM
Sterling 10.25 Vs. 10.5 also maybe 14b - 2pt question hairyboxnoogle Offroad & 4x4 90 12-12-2012 06:25 PM
Brake conversion 8X6.5 to 8X170mm steves_F350_460 1987 - 1996 F150 & Larger F-Series Trucks 0 08-11-2010 03:38 PM
Sterling 10.25 axle shafts in a 10.5? moosebrew Clutch, Transmission, Differential, Axle & Transfer Case 3 07-06-2010 10:04 PM
10.25" STERLING REAR END QUESTION kermmydog Clutch, Transmission, Differential, Axle & Transfer Case 5 10-16-2008 11:02 PM
Tags
170, 170mm, 8x65, bolt, changed, ford, front, hub, mm, pattern, putting, rear, sterling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
