Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-03-2008, 06:34 PM
nebmike's Avatar
nebmike nebmike is offline
Garage is empty, add now
nebmike is starting off with a positive reputation.
Towing with the EL???
Since Ford seemed to see wisdom in putting the axe in the Excursion (jerks!), I'm looking at an Expedition EL -- and while I know its not nearly as much truck, I'm wondering if any of you guys have had much (any?) towing experience with one?
I've got a 30' travel trailer that comes in at about 7500lbs and I'm just trying to figure out how frustrated I'd be trying to tow it in Colorado with an Expy EL.
Thanks in advance for any comments!
__________________
Mike
'11 F350 Lariat FX4, Crew, SB, 4x4, 6.7L, Camper Pkg
2007 Laredo 315RL 5'er, 35', 11.5k, Onan 4k
  #2 (permalink)
Old 01-03-2008, 08:01 PM
rbarbot2 rbarbot2 is offline
rbarbot2 is starting off with a positive reputation.
We tow our 8000 lb. boat/trailer with an 07 Limited (non- EL). It's impressive so be able to maintain the 55 mph speed limit on a mountain grade. I'd think you could probably tow your trailer anywhere. The 6 speed tranny works great, and shifts smoothly.
The load-leveling rear suspension is what makes all the difference in towing a trailer this size. It has worked flawlessly in keeping the vehicle level despite the load on the rear end. Without it, your rear end will likely sag, thus causing the front to feel "light" and have diminished steering ability.
As you've probably noticed, the Tahoe/Yukon can't town your weight, especially loaded with gear, unless you get the hard to find 4.10 geared rear end. The only other vehicle I considered was the Nissan Armada. It has LOADS of power and drives like a sports sedan. The interior is supposed to be new for 08. Haven't seen it, but we would have gone with the Nissan had it not been for the poor interior on the 07 models.
  #3 (permalink)
Old 01-03-2008, 08:23 PM
mnmwhit's Avatar
mnmwhit mnmwhit is offline
mnmwhit is gaining momentum as a positive member of FTE.
I am waiting in hopes that they will offr the same diesel in the Expedition that they are going to offer in the F-150. We do know that it is a twin turbo 4.4 or 4.6 (the same one that Range Rover uses in europe) the HP and tourque will be nearly the same as what my 6.0 in the F-350 has. If they put in in the Expy I will have one of the first in my area. I pull a 33' 10,500 lbs Aluma-lite travel trailer. The fuel mileage while towing will be the biggest advantage. The 5.4 and 6 speed are quite capable to move the load but fuel mileage will suck
__________________
06 F-350, North Pole, Alaska
Brush Guard w/4HID moose lites, Mobil-1 Turbo diesel truck oil every 5000, fuel filters every 10,000 miles, AstroStart auto start, 98 gal Transfer flow tank, Rhino liner on the rockers, EGR delete, MBRP turbo back duels w/ no CAT and SCT Livewire
  #4 (permalink)
Old 01-11-2008, 01:14 PM
07EXPYEL 07EXPYEL is offline
07EXPYEL is starting off with a positive reputation.
I think you'll be borderline or worse if your weight is actually more then #7,000. In colorado you'll have the high altitude which will lower your performance. Everything I've read says you'll loose 2% performance with a gasoline engine (diesels have a turbo) every 1,000' above sea level, so 10,000' = -20%! I intentially bought a light weight 30' trailer to be only about 85% GCVW, which for the 2007 EXPY is #15,000. At #7,000 you'll be at about 95% GCVW. I've been there, and done that with my last tow vehicle and it wasn't pretty.
  #5 (permalink)
Old 01-13-2008, 11:32 AM
72soa 72soa is offline
72soa is starting off with a positive reputation.
I have towed a fair amount with our 07 EL. The biggest load is my IH Scout 4x4 on a tandem axle trailer - about 6000 lbs. The Ford tows that load real well and gets over 10 mpg doing it. I do not have the load leveling or have I used a WD hitch set up. We also tow our boat which is not as heavy but offers a lot of wind resistence. All said I really like the way the Ford tows and am very happy with it. BTW I am in FL and have no input in a mountianess area.
  #6 (permalink)
Old 01-24-2008, 09:11 AM
jakermc jakermc is offline
jakermc is starting off with a positive reputation.
Towing a 30' trailer behind an EL would NOT be considered safe. The issue is wheelbase, not weight. Please read here for some good info on the topic:
http://www.rvtowingtips.com/how-long.htm
__________________
2007 Expedition Limited
2001 F-250 7.3L PSD
Factory Five Cobra Spec Race Car (Mustang running gear)
  #7 (permalink)
Old 01-24-2008, 12:04 PM
I read that same article and rv.net before purchasing my trailer, which also has this comment...
Note: TT=Travel trailer, TV=Tow Vehicle, WB=Wheel Base, GCVW=Gross Combined Vehicle Weight
In my particular case, I am towing a 2001 Prowler 27H (actually 28' long) with a 2003 Suburban 3/4 ton, and I have an Eaz-lift weight distributing hitch and friction sway control bar. I've towed on a few windy days and really don't notice the trailer moving around much, except when the big trucks pass me by. Then I get a little wiggle out of the trailer, but nothing serious or scary. I'm over the first guideline by 3', which I think isn't that bad, but I would not want to be any further over it. And I'm just under the second guideline. I didn't know about these guidelines when I first bought the combination, but I knew I didn't want to go real long with the trailer towing it with the Suburban.
I put a lot or reserach into safety before purchasing the TT that I did. My prior TV was a 1997 GMC Safari Van (Chevy Astro clone) and I was at my limits for weight and WB when towing a 20' trailer. With that TV & TT combo, I had a very scary sway situation that shook the trailer so bad, all 4 hub caps came off. After much research I determined that besides a rather soft suspension, short WB and >90% of max GCVW, I had too light of tounge weight. I weighed my trailer +van and quickly purchased a trailer tougne scale to ensure that I had 10-15% tounge weight. Even though I was using a Reese Dual Cam system, I had errantly loaded the TT too light in the tounge causing the unsafe sway condition.
After I purchased my Expededition EL I could now consider upsizing my TT. From my past experience, I knew I didn't want to get too large of a TT for my TV. After narrowing down my decision to an a Trailcruiser model 30QBSS, I posted questions about towing to the Trailercruiser / R-Vision owner forum @ http://www.r-visioncamping.org/ and found many people safely towing the same trailer with Suburbans, regular length Expeditions F150's, etc..
If this was built like a normal aluminum skinned TT, then yes 30' would be too much for weight, height and length, however this is a lower profile aerodynamic smoothwall lightweight TT with a total length of 31'-7" and an overall heigth of only 10'4" with A/C. The empty weight is only #4,500 and about #5,500 fully loaded for travel. With the Expy EL + my family of 7 + TT, I'm about #13,000 which is still #2,000 under max GCVW. I am still using the Reese Dual Cam sway control, but replaced the spring bars with heavier bars for the increased tounge weight. I have towed about 2,000 miles with this rig sofar and absolutely no trailer sway even at highway speeds of 65 MPH and getting passed by Semi's. I also towed about 1,000 miles with a Husky weight distribution system and a cheap friction sway and still had no problems. My new TT is over 10' longer then my last TT and weighs about #2,000 more but with the Expy EL my towing experience is no longer a white knucke experience. I have plenty of power and vehicle control with absolutely no sway in any condition.
My point is, my 30' TT is not unsafe with my Epxy EL. Safe towing has much to do with the TT design, hitch setup, sway control, TT loading, TV size, and of course TV WB. I'm an Engineer and am very confident decision I made for my Tow Vehicle and trailer without any compromise in the safey of my family or others. BTW, I would not tow this TT with the non EL Expy.
Tags
2006, 30qbss, length, rvision, specifications
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
