2002 7.3 f350 oil leak back near top of engine
Old 01-03-2008, 05:54 PM
mowryj's Avatar
mowryj
mowryj is offline
i have oil leaking from near the top of my engine on the backside. it is not the high pressure oil pump, that was repaired. it leaks about 1 quart every 6 weeks. while i was having my starter replaced the mechanic looked at it and said it might be the intake manifold or head gasket because they were wet with oil. there is no oil in the anitfreeze and no antifreeze in the oil. not losing any antifreeze, just oil. engine seems to run mormal. no codes. is this something to worry about and what could the cost be to fix it? thanks
Old 01-03-2008, 06:09 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
PETE'S_6.0PSD is offline
well. it might be a turbo pedestal leaking or turbo orings, get a set of ornigs for turbo and pedestal , and make sure you EBPV Exhause Back Preassure Valve is not leaking too, they are known to do it. check with the flashlight if you have oil on the top of the motor - in the Valey.
BTW Welcome To FTE.....
Old 01-03-2008, 07:36 PM
mowryj's Avatar
mowryj
mowryj is offline
I'll try that. no oil in the valley either.thanks
Old 01-04-2008, 06:37 PM
mowryj's Avatar
mowryj
mowryj is offline
Question oil leak
I degreased the engine and spayed it off. i don't immediately see any oil leaks after drivind it for about an hour. if it was a rear main seal leak could that spray oil on the backside of the engine near the top also? thanks
Old 01-04-2008, 06:54 PM
Markadeck's Avatar
Markadeck
Markadeck is offline
Gone, but not forgotten
Not likely. I do a whole lot of reading here and think I have only read of one possible rear maim leak. But usually a rear main leak head straight down.
Old 01-04-2008, 07:15 PM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
be kinda hard to get oil up and around the bell housing from inside wouldn't it??
Old 01-04-2008, 07:47 PM
mitchrock1's Avatar
mitchrock1
mitchrock1 is offline
I had the same problem about 5 years ago and it ended up being the turbo pedistal.
Ftwofitty
1999 to 2016 Super Duty
02-18-2011 10:29 AM
ebraunusa
1997-2006 Expedition & Navigator
09-01-2010 06:26 PM
dirtmonkey11
02-14-2010 02:47 PM
ragle27
Aerostar
13
03-20-2009 02:41 AM
rgarces1970
02-06-2005 10:17 AM
Quick Reply: 2002 7.3 f350 oil leak back near top of engine
