Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-03-2008, 05:44 PM
dtvperfect is starting off with a positive reputation.
93 4.6 for 93 4.9
1993 E-150 has 4.9L 6cyl 145hp
I have available 93 4.6 V8 430 hp..(from Lincoln Mark VIII with mods)
Is this a simple bolt / plug in????
Harness match???
Van weighs same as car, different gearing in rear end... but should pull much better...
Is it worth taking 76K mile 4.6 out of $1500 car to put in a great road van? We have a band and we travel in the van. Would love to tow a trailer but the 4.9 won't pull out it's own way.
HELP
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-04-2008, 12:08 PM
Kemicalburns's Avatar
Kemicalburns is gaining momentum as a positive member of FTE.Kemicalburns is gaining momentum as a positive member of FTE.
it will require wiring harness, tranny changes etc.. better option would be to locate an 351w and swap in.
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
installing soon: JBA shorty, Bassani Y pipe, Edelbrock efi truck intake, , aussie front/rear
88 (Rolled)
http://www.supermotors.org/registry/vehicles/detail.php?id=4158
  #3 (permalink)
Old 01-08-2008, 03:22 PM
351???
Quote:
351 will match up???? I had no clue. I would love it if a 351 matched up in the van...
  #4 (permalink)
Old 01-09-2008, 03:40 PM
*********- High Plains
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
I'd go with the 351W also... its a better match and there are plenty of performance parts for the 351W should you get power hungry.
  #5 (permalink)
Old 01-10-2008, 10:39 AM
What will I have to change
Quote:
What will I have to change? Will I need a complete donor?
  #6 (permalink)
Old 01-10-2008, 10:48 AM
a complete donor would make the job so much easier thats for sure.
__________________
94 XLT 5.8/E4OD
4.88 gears f/r
88 (Rolled)
  #7 (permalink)
Old 01-10-2008, 02:33 PM
Mounts and exhaust are the main hard parts, you'll probably need the computer or at least a reflash of your current one, and you'll need the wiring harness for the V8, all easy things to find in a junkyard.
  #8 (permalink)
Old 01-10-2008, 07:19 PM
I'll start looking for a wreck to use as a donor
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
