D2VE heads
D2VE heads
I took a 1972 460 aprt today,D2VE heads.I noticed the pistons looked different than any other 460 pistons ive seen,looks like less dish in them for the open chamber D2VE heads.What would happen if i put D3VE head on this engine.Looks like it would give a higher compression ratio,any one know what i would get? Thanks for any input on this
on
1 Post
D2VE heads
Putting on D3 heads wouldn't raise the compression any, reguardless what piston is in there now. The combustion cambers on D3 heads are the same as the D2 heads. You need to put the early C8, C9 or DOVE heads to raise the compression. The compression ratio you have as it stands is 8.5 to 1 provding that the pistion you have are stock.
77 F250 Highboy 4X4
"The Money Pit"
"If it wasn't for Chevy's my tools would rust"
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=10344&.jpg
77 F250 Highboy 4X4
"The Money Pit"
D2VE heads
The pistons tha are in it now look like all other pistons in 460s ive seen except with a smaller dish,I know the engine has been rebulilt once,maybe someone put higher compresion pistons in it.Just looking at the open chamber D2VE heads it looks like the compresion would be lower with the same piston as used in other 460s. Can you get 460 pistons with different size dishes in them? THANKS
