Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-24-2002, 06:17 PM
bigblockbronco is starting off with a positive reputation.
460 power
how much power does a stock 460 with a carb make
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-24-2002, 07:15 PM
erikl85 is starting off with a positive reputation.
460 power
I think it is 227 hp... I could be wrong though. I dont know about torque, i think it is in the high 200's low 300's (maybe)
__________________
1999 Ford Ranger XLT 4*4 3.0
1977 Ford F-250 2wd 460
  #3 (permalink)
Old 11-24-2002, 07:51 PM
Mil1ion is starting off with a positive reputation.
460 power
What year of 460?
What heads on it?
What carb & CFM?
What do you have for exhaust?
What Intake is on it?
Does it still have an emissions system on it?
Last edited by monsterbaby : 04-01-2008 at 01:56 PM. Reason: removing references to Dennis being an admin from accent post
  #4 (permalink)
Old 04-01-2008, 06:34 AM
four-sixty-power's Avatar
four-sixty-power is gaining momentum as a positive member of FTE.four-sixty-power is gaining momentum as a positive member of FTE.
Someone said my name? Happy April Fools Day!
__________________
Be Careful
Be careful of your thoughts
For your thoughts become your words
Be careful of you words
For your words become your actions
Be careful of your actions
For your actions become your habits
Be careful of your habits
For your habits become your character
Be careful of your character
For your character becomes your destiny
author unknown
  #5 (permalink)
Old 04-01-2008, 12:11 PM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
The late 460s, 1972 and on, were pretty anemic with lower compression and their numbers were unimpressive. The early 460s had 10.5 :1 compression and 365 hp at 4600 and 500 ft/pounds @ 2800.
__________________
Bear 45/70
Gimp Racing
  #6 (permalink)
Old 04-01-2008, 01:50 PM
monsterbaby's Avatar
monsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant future
don't forget that they changed the way the rated the HP too, the difference isn't nearly as big as the numbers look like. If you take the early 460s everyone raves about as a reason to switch to early heads etc you find that they actually only put out about 250hp by 72 standards of rating power (Crank hp vs net) it's been a long time since I seen them but someone dyno'd a 73 460 and it was actually only like 15hp less then the 71 even with the drop in compression and the retarded timing etc (but without all the emissions controls)
But Bear, did you notice when the original post was dated??? old old thread LOL
__________________
Dying's not so bad
It's living that will kill you off
  #7 (permalink)
Old 04-01-2008, 05:12 PM
Bear 45/70's Avatar
It seems four-sixty-power raised it from the dead for April Fools day. Seems he's the fool that digs up dead stuff.
__________________
Bear 45/70
Gimp Racing
  #8 (permalink)
Old 04-01-2008, 10:58 PM
Just trying to bring a bit of entertainment to the day
__________________
Be Careful
author unknown
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
