Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-03-2008, 07:31 AM
michaelbrainardatwor's Avatar
michaelbrainardatwor michaelbrainardatwor is offline
Garage is empty, add now
michaelbrainardatwor is starting off with a positive reputation.
Hydraulic oil blended with Diesel?
I have come across a nearly unlimited supply of lightly used hydraulic oil. Often, our test vehicles and protototypes here at work are filled with oil, tested for a short period of time then torn down and the oil is disposed of...sometimes with as little as an hour of use....sometimes 10-20 hours of use. One of our shop workers mentioned this and asked if I could use it in my diesel...
Has anyone tried?
__________________
2004 Baja H2X/496 HO "Ship4Brains"
24mm Lake of the Ozarks
  #2 (permalink)
Old 01-03-2008, 04:23 PM
monckywrench monckywrench is offline
monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.
What specific oil is used? Get an MSDS (Material Safety Data Sheet) to find out what it is made of.
  #3 (permalink)
Old 01-03-2008, 09:21 PM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
fixnair
I do it all the time in my 02 F350. #32 mostly but a lot of ATF also. I usually run straight oil. I don't blend it but you can if you want. I've even used synthetic hydraulic oil with no noticable drivability problems other than the exhaust smells like an old bus.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 270K miles, 13' service body
1952 F1 flathead Project Truck
2008 Lincoln MKX
need thermostat housing & cab 4 project
  #4 (permalink)
Old 01-06-2008, 03:38 PM
07psdrookie 07psdrookie is offline
07psdrookie is starting off with a positive reputation.
Quote:
Do you heat the oil? I can probably get some hydraulic fluid from work as well. Would that need to be heated as well?
  #5 (permalink)
Old 01-06-2008, 03:50 PM
fixnair's Avatar
fixnair
No I don't heat but then I live in a temperate climate. Temps here rarely get down below 35° I also have a prefilter installed prior to my fuel pump to remove any big chunks from bucket loading my fuel.
__________________
2008 Lincoln MKX
  #6 (permalink)
Old 01-06-2008, 07:29 PM
Wait. Are you running WMO or WVO?
  #7 (permalink)
Old 01-06-2008, 11:56 PM
fixnair's Avatar
fixnair
WMO I guess. It is used hydraulic oil.
__________________
2008 Lincoln MKX
  #8 (permalink)
Old 01-07-2008, 03:25 PM
shorthair shorthair is offline
shorthair is starting off with a positive reputation.
If it is dino based it will work fine if well filtered & you keep the blend reasonable. In warm weather I go 70/30 waste to dino 50/50 in colder temps. Filter at 2 microns through a water seperator before it gos into my tanks.
__________________
90 F250 4x4 sc zf5 3.55 ride-rite air bags on front
  #9 (permalink)
Old 01-19-2008, 08:15 AM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
2010 Ford F-150
D8chumley is a splendid one to beholdD8chumley is a splendid one to beholdD8chumley is a splendid one to beholdD8chumley is a splendid one to beholdD8chumley is a splendid one to beholdD8chumley is a splendid one to behold
tim.burke.167
07psd it is STRONGLY recommended that you don't run anything thru these 6.0L injectors you're not supposed to. The 7.3 injectors weren't as finnicky and I know a few guys that ran various "additives" thru the fuel tank but NOT a good idea for us.
__________________
~ Tim ~
If you can't stand behind our Military, feel free to stand in front of them!
'10 F150 XLT 4X4 CC shortbed 5.4 *5 Star tuned* No Bailout Edition
07 Road King Classic
GO FLYERS! Go Phillies!
  #10 (permalink)
Old 01-19-2008, 08:53 AM
It's a lot easier to justify injector replacement when they cost under $20 than when they sting you over $300.
__________________
  #11 (permalink)
Old 01-19-2008, 09:24 AM
D8chumley's Avatar
Resident smarta$$
2010 Ford F-150
tim.burke.167
Absolutely. I won't do it to my truck but thats just me.
__________________
~ Tim ~
  #12 (permalink)
Old 01-19-2008, 01:47 PM
Quote:
My questions are just for knowledge rather than actually practicing them. I only run an additive (cetane/antigel) in my truck. I've got a buddy at work that experiments on his IDI and he doesn't care what happens to it, so I like messing around on here and getting ideas.
  #13 (permalink)
Old 01-19-2008, 02:40 PM
D8chumley's Avatar
Resident smarta$$
2010 Ford F-150
tim.burke.167
Gotcha, I do the same. In fact I learned that on here, as the contractor that built our pole barn garage told me he dumps the used wmo from his oil changes right into his 06 PSD fuel tank and I inquired about that on here. He said he did it in his older 7.3 and had almost 200k on it and never had a problem with that truck. I asked about that on here and got a firm NO WAY! This site is awesome
__________________
~ Tim ~
  #14 (permalink)
Old 01-19-2008, 05:43 PM
I'd have no problem dumping WMO and Hydro fluid into my tank to save a buck...if the 6.0 wasn't so finnicky, you know. Well, especially since I have 4 years or 90k left on my warranty, I'd rather not void it.
  #15 (permalink)
Old 01-20-2008, 05:27 AM
D8chumley's Avatar
Resident smarta$$
2010 Ford F-150
tim.burke.167
Right! Unfortunately my warranty is gone so I gotsta be careful with MOST of what I do
__________________
~ Tim ~
Tags
73, blending, diesel, ford, fuel, hydraulic, oil, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
