Need Help Really Bad
Im brand new to the Forum and the Wv Chapter. Im having trouble with my truck, well major trouble. I busted the rear diff and thought the cluth out of it. I put a detroit locker in place of a carrier and replaced all bearing,races, and seals. As of today when i shove the cluth pedal down the noise stops and when its out it sounds like your taking a sledge hammer to the tranny. Could I have broke the shaft that goes through the tranny to the transfer. I have a new cluth, pressure plate, throw out bearing, and pilot bearing for to put in it. Just wanting so input on what you guys think the truck would have a story to tell if it could tell one. By the way its a( 2002 Ford F150 XL 4.2 V6 with a 5 spd 4x4) Also any chance I maybe I could find the tranny in a junk yard.
Possom
Possom
Possom
Possom
be sure and replace the pilot bushing. if it's worn it can tear the center out of the clutch disk, been there done that!
I was coming home from work and on the on ramp to the interstate going from 2nd to 3rd and let out on the clutch. When the clutch caught it sounded like a bomb went off where the pressure plate is. After that I had it pulled back to my shop where i work at. I was going 30 to 40 Mph when it all happened . It would only move in low lock. Since i fixed the rear diff it will only move it first and rev.
With only first and reverse something definatly has come loose in the trans, Like the aforementioned shift fork, or worse a rail or gear itself, maybe even a bearing. It really needs to be RDI'd to tell the full story, I would start pricing used and rebuilt units. One thin I remember from my shop days, Depending on the insurance company, if you have Full Coverage, some companies will cover engines, transmissions etc.
