Power Window issue...
Guys:
My power windows do not work. No motor.. no clicking.. nothing. The Power Windows do not work at any door switch.. the window lock is not on. It's not the 30a fuse because the moonroof works just fine.. The lock button works.. the lights on the switches on the driver side are on.. I don't know.. any ideas?
Check the plug that is located in the Door Jam on the 2004 F150's and newer. There is a wireing block that tends to corrode, apply a good amount of Die-electric grease to it and check all of your contact pins and sockets to ensure that non are broken from corossion. My, window on the Pass side stopped working and that was what the problem was.
mrjimbov
Electrical Systems/Wiring
11-23-2014 07:20 AM
