Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Cleaning and Detailing Guides
- How to Eliminate A/C Smell
Step by step instructions for do-it-yourself repairs
Musty A/C Smell?
The musty smell is from the unit being run in recirculating mode too often.Spraying lysol does work but has its risks. Lysol can catch fire very quick and once the mist hits the open blower motor resistor it can cause a fire.The stuff the dealer uses is called ozium you can get it at walmart and many other places. Its the same stuff used in hospitals to control bacteria. it looks like this http://www.restockit.com/Ozium-Glycolized-Air-Sanitizer-64-oz-Vanilla-Scent--(WTB53131CWD).html?source=froogle
I used to work in an automotive A/C shop and the Lysol thing is what we did for the musty smell prople complained about.
Put the unit in recirc and shoot it right into fans intake.
Never heard of one catching on fire from this, but since propane is the propellent used these days I wouldn't discount the possibility either.
you might want to know where a fire extinguisher is, just to be on the safe side.
A/C leaks water on passenger side floor.
It was one year and 25,000 miles of ownership before I discovered the A/C leaking water. I might not have discovered this if it was not for the see-through clear floor mats that I recently installed. Since the floor mat is see-though I had noticed water condensation on the backside of the floor mat.
2007 and 2008 Ford Expedition have a design flaw which causes the A/C evaporator coil housing box to condensate and leak water on and under the passenger side floorboard carpet. The water will run down the firewall behind and under the carpet so it may not be noticed. This is caused by a lack of insulation.
The AC evaporator coil is located on the passenger side under and glove compartment box. To test for the water leak, take a paper towel and lay it out on the left side of the passenger side floor carpet, making sure you tuck and fold some of it up over and behind the carpet between the firewall. (The firewall is the metal wall that separates the passenger compartment from the engine compartment.) Now go for a drive with your A/C on for awhile, if the temperature and humidity are just right, it will start to condensate and drip and leak water.
This can cause mold, making the inside of the vehicle smell bad and have a musty odor, and ruin the carpet and carpet padding, and overtime rust the floorboard.
I have pictures on my website at…. http://www.Baumbach.com/Expedition.htm
