Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Cleaning and Detailing Guides
- How to Eliminate A/C Smell
Step by step instructions for do-it-yourself repairs
Musty A/C Smell?
Most of us have automatic climate control. If you turn the air off, it closes the outside air door and traps the moisture. Shutting the truck off with the air or heater on WITHOUT the recirculate mode active should leave this door open and help a bit. Not a good design.
I was having this problem in the spring where it blew this foul smell out in the mornings in the spring time (4 season climate). However it seems to have gone away now that the summer weather is here.
With regards to running the heat for 5-10 mins that would be an acceptable solution if this were the 60s but we are talking 2008 here!
Referance A/C leak
I emailed the information and pictures to my local Ford dealer, who in turn called Ford, who said they have had no reports of this issue and had no fix for it. Ford advised the dealer to apply insulation tape to the outside of the evaporator coil housing box. This is black colored tar looking stuff that comes in rolls about 2.5 inches wide that is in the dealer’s inventory.
When I get time I will drop it off for the dealer to do this, but I do not think the R-factor will be enough. I think for better insulation that a fiberglass on one side and aluminum on the other would have a much higher R-factor.
Since the dealer’s inventory is limited, I think I will stop by Home Depot and see what insulation tape they have with the highest R-Factor , because I know I am going to end up fixing this myself.
p.s.
The R-factor determines the level of insulation provided by a substance, the higher the number the better.
p.s.
Berry, you may have just hit on the answer to the cause of the odor, are you missing any of your work socks?
By the way, I believe we had a discourse a month or so back about this spending money on new pieces and parts for a new truck, and now your on to buying something else. The stock markets down, my retierment funds are getting none existent, as are my wife's-ya get my drift- I'm having a hard time keeping up.
By the way the HID lights had a problem and are going back for refund. Taking the head light assemblies out to work on them makes me nervous . One day I'm going to drop or scratch one. Ya all have a good day, ya hear!
I never did get the waster leak fixed.
I maintain a website with all the repairs and fixes I do at
My 2008 Ford Expedition Limited ownership experience, maintenance, defects, add-ons, service tips and more
#29
I know all of the posts were concentrating on the AC drain being the issue. But also be sure it is not a coolant odor.
I thought my AC condensate was the source of my odor. Had a local Dealer check it out and do the disinfectant spray. Smell came back. Eventually one day about 2 months later while driving I got a puff of vapor out of the passenger side of the hood. When I stopped, I found the upper heater hose had sprung a leak and it was pooling on top of the engine. Same smell. Turns out the heater hose had been leaking minutely all along but so little that I never had noticed a puddle of coolant on the engine until that final day when it started leaking more (dealer service missed it too). Even this was still not enough of a leak to puddle on the ground. Replaced that heater hose and no more odor.
#30
Baumbach
37
07-14-2022 08:40 PM
winginit
10-31-2015 04:38 PM
