Truck Failed Inspection - Ford Truck Enthusiasts Forums
Delaware Chapter Join Chapter, Leader: fire240
Old 01-02-2008, 04:42 AM
CollinsCD's Avatar
CollinsCD CollinsCD is offline
CollinsCD has a good reputation on FTE.CollinsCD has a good reputation on FTE.CollinsCD has a good reputation on FTE.
Cool Truck Failed Inspection
I have a 1979 F-250 with a 351M 2 barrel that failed the CO part of the Delaware emissions. Does anyone know of any tricks to help me get this through? Do I have to lean out the carb a bit?
Thanks!
Old 01-02-2008, 07:45 AM
danlee's Avatar
danlee danlee is online now
danlee has a good reputation on FTE.danlee has a good reputation on FTE.danlee has a good reputation on FTE.
Carbon Monoxide or CO is formed by combustion in an over rich mixture. The idle screws will only lean the mixture at idle. If your engine failed at part throttle, it cannot be fixed with the idle screws. It may be due to some problem in your carb or intake. Do you have a clean air filter?
Is your carb float setting or your fuel pressure right?
What color are the plugs? Do they show a rich mixture?
How is your Hydrocarbon reading? Rich mixtures should also produce high Hydrocarbons.
Old 01-02-2008, 07:59 AM
tewferford's Avatar
tewferford tewferford is offline
tewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant future
I agree, You might wanna pick up a rebuild kit and give the carb a good cleaning.
Old 01-02-2008, 08:55 AM
CollinsCD's Avatar
The emission inspection was done at idle. The hydrocarbon portion of the test passed very well. The air filter was recently replaced and I have not check the plugs as of yet. Maybe some carb cleaner and lean out the carb a bit????
Thanks!
Old 01-02-2008, 09:27 AM
tewferford's Avatar
Was there anything they tried to get you within limits? They should have tried some minor adjustments eg. adjust carb/timing before failing you. Do a search on this site for sea foam, the stuff works awesome.
Old 01-02-2008, 09:32 AM
danlee's Avatar
Reduce the idle RPM as low as possible, get it smooth, then lean it a litte more.
Old 01-02-2008, 09:35 AM
CollinsCD's Avatar
Thanks danlee! Do I lower the idle using the mixture screw?
Old 01-02-2008, 09:51 AM
danlee's Avatar
Quote:
No, there is a seperate idle speed adjustment. It sould be where the linkage connects to the throttle arm.
Old 01-05-2008, 09:05 AM
toadx8u's Avatar
toadx8u toadx8u is offline
toadx8u is gaining momentum as a positive member of FTE.toadx8u is gaining momentum as a positive member of FTE.
bump up your timing...
Old 01-08-2008, 04:47 PM
boosted46's Avatar
boosted46 boosted46 is offline
boosted46 is starting off with a positive reputation.
get your temp up also as this will help keep it lean, just don't go to hot.
Old 01-08-2008, 05:03 PM
toadx8u's Avatar
higher heat range plug will help too
Old 01-09-2008, 04:16 AM
CollinsCD's Avatar
Thanks for all the information guys! I have been busy and have not had time to work on the truck. Hopefully, this week I will try some things and if I have time I will run it through. I will report my findings.
Thanks!
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
