01-01-2008, 11:26 PM
IMO, the first step would be to pull codes, to see if the computer sees a fault in the TPS.
TPS is a simple potentiometer. Basic test procedure is to put an ohmmeter on it and see if the resistance changes smoothly across it's range of motion. You'll want a wiring diagram so you can properly identify the three leads.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
