Im replacing my timing chain cover(after i broke it) and I have everything off and the cover is moving but it wont get past what i believe is the oil seal...The oil seal wont come off because there is a sort of pin that the harmonic balancer slips over. So if anyone could tell me how to remove the cover from the crank it would be appriciated...Thanks
Yea how do you remove the pin to pull off the sleeve?
They can really be tough to get out if they've been in there a long time you can try tapping a screw driver in a the end of the key and then that will wedge under it and pop it out
