Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-01-2008, 09:12 PM
JCastellaw is starting off with a positive reputation.
front end and transfer case flush?
My bronco set up for about 6 years. I have a new motor and changed the fluid in the tranny. What should I do the the front and rear end, transfer case? Seafoam? MMO? Or just drain and change???
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-01-2008, 10:41 PM
dodmort's Avatar
dodmort is starting off with a positive reputation.
i have been draining and changing mine for 24 yrs.
i do it two times a year since i am in the water so much.
i did drill a vey small hole in the 9" to make it easier and put in a sheet metal screw out of the way so it would not snag anything to make the drain plug.
do put in some equa torque each time but still running original parts except for outer bearings.
  #3 (permalink)
Old 01-02-2008, 08:35 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
Pull the cover on the front axle and the PTO cover on the transfer case is the best way.
As for the rear end, they make a suction gun that looks like a grease gun that you can put into the rear end to get the old oil out.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #4 (permalink)
Old 01-02-2008, 10:04 PM
dodmort's Avatar
draining the 9 " on My shelby, of course, i use the suction gun.
no way im drilling a hole in my 9" on that.
but the very little hole i put in the very edge of the bottom of the "bump" of the 9" on the bronc sure gets it all out. but not to fast in the winter.
at my age to laying on my back without a lift( add wish list ) i try to keep to a minimum...
  #5 (permalink)
Old 01-03-2008, 04:40 PM
RCrawler's Avatar
Personally, I wouldn't trust a sheet metal screw from rattling out. The best option is to remove the drop in, drill and tap (or weld a bung in) NPT threads in the bottom of the housing. I never understood why Ford didn't build them this way.
Jason
__________________
  #6 (permalink)
Old 01-03-2008, 06:16 PM
dodmort's Avatar
i know .
i know
the set up is just a little "coyote"
the shelby has a large diameter plug on the back so it is easy to get suction gun into.
as you know a 68 EB you can just barley get your little finger in the fill hole...
the dana 60/70 set up i am building to keep my EB out of the water will solve all this.
but that is a different post.
  #7 (permalink)
Old 01-05-2008, 05:05 PM
Good to see you back rock. you disappeared for a while!
  #8 (permalink)
Old 01-06-2008, 12:56 AM
RCrawler's Avatar
Thanks. I'm very busy these days. Just bought a house and started a new job. And with 2 kids, I'm always on the go with them.
Jason
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
