Fuel bowl Heater element Replacement - Page 2 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-08-2009, 10:50 PM
agg_bagg agg_bagg is offline
agg_bagg is gaining momentum as a positive member of FTE.
ya the updated one looks like this. and that is probably what your new one looks like.
Old 11-09-2009, 12:55 AM
ztodd377's Avatar
ztodd377 ztodd377 is offline
of FTE, RHN, and BEER!
ztodd377 is gaining momentum as a positive member of FTE.ztodd377 is gaining momentum as a positive member of FTE.
Yep, that's exactly what mine looks like. So that's the newest one?
Old 11-10-2009, 04:19 PM
jeep1947 jeep1947 is offline
jeep1947 is starting off with a positive reputation.
Yep and I am gonna try it in my 97 obs just to see if it helps on start-up running B100. Normally I plug it in on a timer set for about 3 hours before I use the truck. Just playing to see what happens.
Old 12-23-2009, 11:26 PM
Terry D. Crowson Terry D. Crowson is offline
Terry D. Crowson is starting off with a positive reputation.
Fuel Filter Heater
Quote:
Originally Posted by bfife View Post
There are 2 styles. the pics are of the newer one. if you have the older style you will see a 3/4 inch "nut" cast into the bottom of the black plastic standpipe,and you will not have the 2 torx headed screws. that stand pipe it LEFT HAND thread. While cleaning, check the screen that covers the port going to the fuel pressur regulator. they will get clogged and restrict flow and affect preformance. Barney
I have this older type. Is it the standpipe it self that tightens or is it the nut ? Thanks, Terry
Old 12-24-2009, 12:01 AM
damicofuel's Avatar
damicofuel damicofuel is offline
damicofuel is gaining momentum as a positive member of FTE.
I wouldnt spend the money on it. After the truck is running, the engine heat will do what thad does anyway. Spend the money on MODS!!
Old 12-24-2009, 05:53 AM
bfife's Avatar
bfife bfife is offline
still plays with trucks
bfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to behold
Quote:
The standpipe.
Welcome to FTE and Merry Xmas
Barney
Old 12-24-2009, 06:19 AM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
Quote:
a bowl heater isnt going to help the B100..we cant run anything over a B10 in the winters up here...i dont think the bowl heater helps much at all..i took my bowl out 2 winters ago and she still fires up every day and has never gelled...i never even pluged her in last year and she always started...
Old 12-24-2009, 07:29 AM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Plugging the motor in will have no effect on the fuel in the tank. Even if the fuel bowl heater did magically work, it would only work on the stuff inside the fuel bowl. The rest of the fuel tank and lines would be plugged with gelled fuel.
Pour some B100 in a clear plastic bottle and stick it in the freezer for 24 hours, or stick it outside if it's cold. That will tell you everything you need to know.
Old 12-24-2009, 08:32 AM
The standpipe.
Barney
I appreciate it. Any idea on the best tool to use to loosen the pipe? Thanks again. Merry Christmas !!
Old 12-24-2009, 09:15 AM
bfife's Avatar
A deep clearance socket or a crowsfoot. I wanna say its a 3/4, but I'm not sure. Its been awhile since I've done one.
Old 12-24-2009, 10:12 AM
It appears to be a flared rounded head ??
Old 11-06-2013, 09:58 AM
angrygerman angrygerman is offline
angrygerman is starting off with a positive reputation.
Thanks Guys!
I was afraid I was gonna have to pay an arm and a leg to get some BS fixed, come on here for 10 minutes and problem solved. So thank you again.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Salvage yards Oklahoma Chapter 14 04-11-2003 11:33 PM
Tags
1997, 73, 99, bowl, diesel, element, element73, f350, ffuel, ford, fuel, heater, power, replacement, sd, stroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
