Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Southern Region Alabama, Arkansas, Florida, Georgia, Kentucky, Lousiana, Mississippi, North Carolina, South Carolina, Tennessee and Virginia.
  #1 (permalink)
Old 01-01-2008, 05:05 PM
vunger1 vunger1 is offline
Garage is empty, add now
vunger1 is starting off with a positive reputation.
99 f-250 4x4
hello im new to this forum and i have a question,
My truck got stuck in 4wheel low the other day.I kept messing with it and i finally got it back to 4 wheel hi.never could get it out of 4wheel high though.
So at this point i decided to remove the drive shaft to the transfer case.The front wheels quit pulling ,but the transfer case still is stuck in 4wheel drive.So i pulled the electric shift solenoid off of the side of the transfer case and manually (with a wrench) put the transfer case in 2-wheel high.So im driving down the road and the transfer case (without a front drive shaft)kicks into 4wheel (possibly centrifical clutch in transfer case) and really gears down so i cant drive normal speed.So i stop crawl under the truck and the shift position is still set to 4wheel drive.I have ordered a new switch solenoid ,is there any way i can drive without the transfer case kicking back into 4-wheel drive ?The part will not be in for a couple of days and this is my only transportation.
  #2 (permalink)
Old 11-07-2008, 09:05 AM
93f1505.0L's Avatar
93f1505.0L 93f1505.0L is offline
93f1505.0L is starting off with a positive reputation.
You could try turnning your electric motor to @WD and then the T-case to @WD and re install the motor. That might keep in 2WD. If not you will have to figure out how to have someting hold it in 2WD.
__________________
96 F250 7.3L 4X4 E4OD Ext. Cab.
Dana 60 front, Stage IIs
Tags
4x4, 99, activated, centrifical, f250, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
