1969 F600 HD brakes - Ford Truck Enthusiasts Forums
1969 F600 HD brakes
Old 01-01-2008, 03:02 PM
chessman21 chessman21 is offline
chessman21 is starting off with a positive reputation.
Arrow 1969 F600 HD brakes
Can some body tell me what kinna of brakes this truck has? The Booster is under the cab that has some kinna air induction tube runs up to behind the seat just abouve the gas tank, and the master cylinder is behind the pedal on the fire wall. Problem with it is i have to push them really hard to get the truck to stop with a half load and i want to fix this befor something bad happins. I was told to check/replace the booster and i cant find nobody localy that knows anything about it. Including me<
Old 01-02-2008, 11:12 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Welcome to FTE
From your description, it seems to me that the booster is going bad.
List the AXLE code from the Warranty Plate-left door near the latch.
I need to know the axle weight capacity before looking to see what brake system you have. I need the last 6 digits of the VIN also.
I took a qwik look in the parts catalog at the types used in 1969:
With single hydraulic vacuum brakes = only one type, axle code not needed.
With split hydraulic vacuum brakes = there's at least 6 types > >
Need to know the VIN, the size of the brake shoes: 14 or 15 inches, the diameter of the booster, the axle capacity.
The axle capacity, as previously mentioned, I can decode from the axle code.
Old 01-02-2008, 06:22 PM
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.
Number Dummy is everywhere!! LOL After Bill gets you the info--Joblots in N.y. CITY CAN GET YOU A BOOSTER!! I got 2 of mine there!!! Bill
Old 01-03-2008, 02:18 AM
OK, i will get the info requested asap,. Its actually a HD, tranny drivin pto twin piston cab controlled dump truck with 2 speed rear axle. I think its allso referd to as a "5 yard" truck.. it weight is 9500 lb's empty. It has a 330 FT engine.
It will dump a full 14' bed of wet dirt in about 7 seconds.
Old 01-05-2008, 09:38 PM
OK, im not sure what set of numbers is the ones u need, heres what i got from drivers side door in the order they apper.
F10YEF53263
115 2M F103 L 81 G A1
04500 175 4000 22
Old 01-05-2008, 11:23 PM
After looking up the vin i posted that maynot be the original door, but then again the decorder i was useing was kinna hard to understand with limited info.
On the up side i found what looks to be a match to the booster i have. The picture and messurments are the same and the id tag thats on the mounting bolt matches.
Says its a "hydro vac booster" .. I may have misunderstood what i read about hydro vac brake sysems but dont they run off the power steering unit somehow? My truck has no pwr steering the vacume comes of the intake manifold beside the carb that runs down the fire wall down to the booster under drivers side.
Old 01-06-2008, 12:08 AM
390Highboy 390Highboy is offline
390Highboy is starting off with a positive reputation.
Yep, your booster is definetly bad. Don't haul anything else until you fix it. My dad has had three of these trucks and the booster can completely go bad all of the sudden making it difficult or impossible to stop with any kind of a load.
Old 01-06-2008, 05:23 AM
I may have misunderstood what i read about hydro vac brake sysems but dont they run off the power steering unit somehow? No, that's a Hydro-Boost My truck has no pwr steering the vacume comes of the intake manifold beside the carb that runs down the fire wall down to the booster under drivers side.
Hydro-Vac's are remote mounted power brake boosters.
A Hydro-Vac is NOT a Hydro-Boost...two different systems entirely!
The door info you posted above is wrong (F10 = F100 / it should be F60 = F600).
Someone swapped doors and didn't rotate the old VIN to the replacement door.
Old 01-06-2008, 06:15 PM
ok thank you for this info i will get the booster. were mite i find brake cylinders shoes and drums for this truck? I put new rim/tiers on the front 2 years back and i think the rims were 20 inch rims or maybe it was the tiers, it was 20' something. The cylinders leak pretty bad now and i have to pump them up from nothing after 3 days of sitting.
Iv googled high and low and i cant seem to find any info.
Old 01-06-2008, 07:41 PM
My dad and I just finished restoring ours and he got all of his brake parts from the local Auto Star and Napa parts stores. I know he bought new shoes, wheel cylinders, and brake lines for it. The drums might be harder to find. Ours were good enough that we just sanded them down and put them back on.
Old 01-07-2008, 03:42 AM
Outside, on the edges of the drums are Ford ID numbers. If you need new ones, post the ID numbers...there's dozens and tough to figure out without those ID numbers. As suggested above...most of the parts can be bought from autoparts stores. NAPA will be your best bet, and for hard to find stuff: joblotauto.com, this company specializes in older BIG Ford truck parts.
Old 01-07-2008, 02:51 PM
Thank you for the info,, i will get the numbers and get back here asap
Old 01-26-2008, 03:35 PM
ok i took some picture of my wheels and posted them on my web page.
See if the brake shoes/calibers can be identified from here. I was allso told the king pins need to be replaced as well.
My page is f600.chessman21dotcom
www.f600.chessman21.com
Old 01-28-2008, 11:02 PM
drum numbers
Ok, here are the numers on the drum.
MAX DlA 14 090 <the "l" in DlA is questionalbe could be a "1">
133 20A
3417
GUNITE
3 sets of numers one word spaced out kinna even around the edge of the drum.
Old 01-29-2008, 03:30 PM
MAX DlA 14 090 <THE a ?1? be could questionalbe is DlA in ?l?>
133 20A
3417
GUNITE
3 sets of numbers one word spaced out kinna even around the edge of the drum.
The numbers you posted for the drums are not in my cross reference catalog.
However, from the looks of things (MAX DIA 14), you have 14" brakes...and luckily, there only ONE type.
The axle weight is either 5,500 or 6,000 lbs. front axle capacity.
Brake shoes are 14" x 2 1/2"
Front wheel cylinders are: 1 1/16" in diameter.
King Pins: 1964/72 F600 5500 or 6000 lb. axle capacity: C3TZ-3111-A
FTE sponsor GREEN SALES has 10 sets of these king pins sets in stock: 800-543-4959 EST.
Power Brake Booster Old Hickory 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 01-03-2015 11:59 PM
'65 Brake Booster Question johnmel59 1961 - 1966 F-100 & Larger F-Series Trucks 0 10-29-2014 07:14 PM
55 F750 Big Job brake booster Snowturtle Large Truck 9 08-14-2014 01:07 AM
British Type Remote Brake Booster? NapaRick 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 04-09-2014 12:55 AM
Remote brake booster question GB SISSON 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 03-13-2014 10:12 PM
Tags
1964, 3417, 69, axle, brakes, cylinder, drum, f600, ford, front, gunite, hydroboost, hydrovac, identification, rear, repair, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
