'04-up F-150HD (8200GVW)
Would appreciate some info on the rear axle of the high GVW F-150 rear axle. I have a lot of info on Visteon axles but very little on the 10.25, semi-float used in the HD '150s.
Here's what I know:
Ring Gear Dia: 10.38"
Hypoid Offset: 1.50-in.
GAW: 5,300#
Nominal GCVWR: 17,000#
Maximum Output Torque: 8,300 lbs-ft (short term)
Continuous Output Torque: 2,000 lbs-ft
What I want to confirm:
Axle shaft: Spline count, spline diameter, minor spline diameter (or shaft minimum diameter) (Note I believe it to have 35 splines like the previous 10.25 semi-float)
Axle Tubes: Outside diameter and wall thickness (no idea on this)
Many thanks!
Here's what I know:
GAW: 5,300#
Many thanks!
BandBFord: Thanks for looking, but I'm sure that is incorrect. I have several recent Ford Data books that list the same thing and also for the 9.75-inch... yet I have pulled 9.75s apart and they have 34 spline, 1.37-inch shafts. Also, if you look up various locker and limited slips for the 9.75, they list the same. Nobody lists a unit for the 10.25 semi-float in the '04 up F150 HDs specifically but I doubt the bigger, higher GAW/GCVWR rated 10.25 ring gear axle for the HD is going to have smaller axle shafts than the smaller, lighter-rated 9.75 axle. What I am trying to figure out is if I can swap the Truetrac from my '86 10.25 full-float Sterling over to this newer semi-float. The carriers in the 10.25 full float and the old '85-93 semi-floats interchange (both had 35 spline shafts) and I expect they do as well for the F-150. I just like to have things figgered out before I open the toolbox (as much as possible anyway) to minimize downtime.
