[quote=str8pmpn4l]1st vist 10/05/06 mileage: 32370
1.)Code 69---- performed IDS test to verify
DTC P-0401 and performed test/check 1 thru 5 on perf. sheet performed PID data monitoring and pinpiont tests remover and inspected EGR valve - badly cooked up replaced EGR valve assy.
2.)cleaned out
intake ports and run
engine to clean out cleared
DTC and road tested ok- retested pass DTC verified repairs ok
2st visit 03dec07 mileage: 47160 (diff
dealer that the first)
1.) tech code p123b
2.)reflashed pcm,tcm and ficmto latest calibration file
3.)I had a
intake on the
truck they reinstalled the stock air box
4.)they say the problem with the veh. is the air pressure not being read correctly by MAF sensor
3rd visist 07/02/07 Mileage: 58,756
1.)performed
diesel driviabilty diagnosis. retrieved CMDTC p0401 and p123b
2.) performed boost test/no boost
3.)perform VGT test (6005f25) turbo failed test
4.) performed TSB 06-23-3 removed turbo and disasembled. inspected and cleaned turbo reinstalled and repeat boost test. now
truck makes only 30 psi boost.
5.)smoke test
intake and
exhaust for leaks and found a leak in turbo inlet pipe from left exhaust manifold. removed turbo and y pipe,pipe was cracked at flex joint. installed new inlet pipe. reinstalled turbo and repeat boost test 24 psi boost now
6.) clear KAM and relearn VGT startegy
this is just a few thing that have been done. thre is no more intake on the truck and there are no tuners as of yet....... the truck is stock basically it has a lift kit thats it..... y\it a automatic torqueshift also the truck does blow white smoke not all the time but some of the time........
