429 heads on a 1992 460EFI??
I have inherited (a long story...think teenager)a 1992 F250 4x4 that has had the original motor replaced. The truck now has the 460 block with 71' 429 heads, with the EFI. The truck has run with this combination, but it never has run right.
I guess my question is that are these 429 heads compatible with the EFI...or should I start looking for a pair of EFI460 heads.
Any help would be appreciated
Thanks
Thanks
The old heads have bigger ports that are lower than efi intake. They can be made to match up but you have take off material on the top of the ports on the heads and add material to the bottom of the intake. Otherwise you get a leak into the valley of the engine.
