1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
EGR probems
Old 12-31-2007, 09:50 PM
theguy_88's Avatar
theguy_88
theguy_88 is offline
Question EGR probems
have a 05 f-350 6.0 powerstroke dsl. i have put a banks powerPDA and after reading the OBDll codes two codes came up. the codes and defintion are "P0404 EGR, EGR control circuit range/performance EGR sensor or valve, EGR position circuit" and "P0405 EGR, EGR sensor A circuit low open circuit, short to ground, EGR position sensor". what is my problem and how can i fix it, also do i have to orderin any parts?
Old 12-31-2007, 09:58 PM
ken kenmnedy's Avatar
ken kenmnedy
ken kenmnedy is offline
isnt that egr stuff covered under warrenty????
Old 12-31-2007, 10:14 PM
theguy_88's Avatar
theguy_88
2005 with 1006000km on the truck no warrenty.
Old 01-01-2008, 08:50 AM
TimMcGraw67's Avatar
TimMcGraw67
TimMcGraw67 is offline
I know working for International I have seen quite a few of those EGR Valves go bad and hate to say it but it does a special puller as it is easy to break the ears off on the valve
Old 01-01-2008, 09:14 AM
03KingRanch250's Avatar
03KingRanch250
03KingRanch250 is offline
Check out the tech folder in the 03-07 6.0 forum. It gives some great insight on removing the egr to clean or replace.
Old 01-01-2008, 10:39 AM
Dwinkie's Avatar
Dwinkie
Dwinkie is offline
OH yeah it takes a REALLY SPECIAL puller, same one I use to remove carrots from my garden teehee. we all(well mostly) have two of them
Old 01-01-2008, 12:41 PM
03KingRanch250
I used a welding rod.
Sgt93
6.7L Power Stroke Diesel
02-05-2018 12:48 AM
BigB1975
02-28-2014 07:35 PM
och
06-09-2013 01:49 PM
delano79
08-30-2011 08:36 PM
OZX1
06-16-2007 07:10 PM
Quick Reply: EGR probems
