Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-31-2007, 09:38 PM
mx256 is starting off with a positive reputation.
04 diesel
Are the 04 6.0L diesels something to stay away from. I am buying a new truck and just wondering if I should just stay with the 7.3 or go with the 6.0. I did a search and found a lot of people posting problems on the 6.0's but thought I would ask what you'll thought.
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-31-2007, 09:51 PM
07psdrookie is starting off with a positive reputation.
Touch and go. Some motors get a couple hundred thousand on them with proper care and very small problems. Others get bought back. Somebody else chime in any time....
  #3 (permalink)
Old 12-31-2007, 10:00 PM
johnjohn2784 is starting off with a positive reputation.
a lot of people have had problems with their 03/04's and will tell you to stay away. I personally used to own a 2004 psd and it was an amazing truck with no problems. Strong as could be...def take it for a ride and run an oasis b4 you buy.
__________________
2008 6.4L Black F-350 ext cab short bed.
  #4 (permalink)
Old 12-31-2007, 10:01 PM
PatrickO is starting off with a positive reputation.
2004 F350 4x4, here. 62000, ten thousand of which have been from yours truly. I'm lifted and spinning 37's (read: not easy on the drivetrain) with a heavy foot. I drive it like it's stolen but take care of it pretty well - I have had no issues to speak of. As well, my Oasis is mostly clean and doesn't display anything note-worthy. Care for it properly, including fluid changes, warm-up/cool-down times, etc., and you'll do well. (Assuming it hasn't been abused and has a clean history).
  #5 (permalink)
Old 12-31-2007, 10:09 PM
CO250 is starting off with a positive reputation.
I agree with Patrick - take care of it and it'll go a million miles. My 04 has 81000 on it, and the only problem has been a replacement oil pressure sensor, which was covered by the warranty. I've been really impressed with it and love it. I imagine most of the problems which have been posted in regards to the 6.0 developed in fewer miles.
__________________
04 F250 PSD
73 Bronco
  #6 (permalink)
Old 12-31-2007, 10:44 PM
yeah I have a 7.3 now but found a good deal on a 6.0 with 76 thousand miles on it and didn't know if it was worth it or not. Who knows I may just play it safe and keep the 7.3 but man I love all the little features of the 04 interior
  #7 (permalink)
Old 12-31-2007, 10:50 PM
Get an 05' or newer (depending on how much you want to pay). There's been significantly fewer problems. Then again, the 7.3s are a great motor in their own right. If it's not broke, don't fix it.
  #8 (permalink)
Old 01-01-2008, 12:22 AM
doubledee715's Avatar
doubledee715 is starting off with a positive reputation.
doesn't matter what year. hit or miss. haven't been in for one warranty concern other than recalls.
__________________
David, 2003 f250 6.0 cc sb Centennial Edition, Dieselsite coolant filter, afe stage 2 w/pg7, ejf1000 edge juice w/attitude replaced w/innovative tuned xcal, blocked off egr cooler, Quadzilla Commander w/pillar mount, ARP studs, ITP RR, 05 accufab elbow, 4" tb, pic
  #9 (permalink)
Old 01-01-2008, 12:37 PM
yeah I am only looking into a different truck because this short bed isn't doing it, I need a long bed.
  #10 (permalink)
Old 01-01-2008, 07:26 PM
D8chumley's Avatar
Resident smarta$$
D8chumley is starting off with a positive reputation.
Maybe cheaper to buy a small trailer?
__________________
'04 F250KR CC FX4 6.0 swb,5" GR Aussies,6.5"Superlift,37" ProComp X-AT's,ccv,zoodad,fumoto,RanchHand front,AutoMeter 3pod,coolant filter,Silverstars,SCT X3 soon...132k
04 Explorer Limited-wifes
Tim
Go Flyers! Go PHILLIES!
  #11 (permalink)
Old 01-01-2008, 08:33 PM
wrangler76 is starting off with a positive reputation.
I've got a late '04 with 57k miles. No problems other than a harness recall that I need to get take care of. I'm not gentle on it running 5.5" lift and 37" Toyo M/Ts.
__________________
Adam
Carson, WA
"Meller Yeller" - '79 F-350 4x4 Supercab, Built 356 series
'04 F-250 4x4 Supercab, 6.0 PSD
  #12 (permalink)
Old 01-01-2008, 11:44 PM
dayooper is starting off with a positive reputation.
I have a 04 and i have replaced under warranty 2 egr's, turbo, and it is in right now for intake gaskets, I also suspect a leaky up pipe. At my own cost hubs, oil changes, regular maintenance ect. My dad has a 05 excursion lots of front end problems, and it is going in for head gaskets as soon as mine gets out. as stated above it is touch and go drive it and look how long it sat because that will kill the turbo if it has sat for an extended duration.
__________________
713co sappers
"do or die trying
04 Ford F250 CC LB 6.0
4in superlift
4" 409 turbo back MBRP
APR studs
EGR Liberated
Kitty ran away
auto meter sport comp Trans temp, Oil pressure, volt, pyro, boost
Recon clearence
315-75-16 Toyo Open Country MT
  #13 (permalink)
Old 01-02-2008, 08:21 PM
yeah I am just going to try and find another 7.3 or wait and save some cash to get an 06-07 model. I can't just buy a trailer, I pull a goseneck and need the longer bed as I can't pull it with my truck now cuz it knocks out the back window.
I went to the dealer today and he had to move a 6.0 out of the way (an 05) and he let it cycle and tried to crank and nothing then did it again and it finally started but made the most horrible sound I have ever heard. Sounded like someone striking a hammer on a metal table. The 7.3 I looked at started right up and it's 11 degrees out today.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
