From a Carbed 460 into a Fuel Injected 460..
I heard from someone that you can turn a carbed 460 into a Fuel-injected 460, by taking everything(intake, injectors, wires, computer) off a fuel injected 460.
Will this work?
Has anyone done this?
Can they give me a list of things that are needed from the donor vehicle?
What needs to be installed where?
I would like to do this on my 460, but want to find out what the details are first
Will this work?
It is possible, but like Brian said you need to replace everything from the heads up, and instal the high pressure fuel system. If you do this you WON'T make more power, you may loose power, but the driveability is greatly improved.
Nick from the frozen north
1974 F-250 4X4
soon to be 429
dana 60 front and rear
1974 F-250 4X4
soon to be 429
>may loose power
>What are the power differences between the, say 86 460 with a carb, >and the '87 with FI?
If I remember correctly, both the carbed '87 and the EFI '88 were 230 HP @ 3600 and 390 TQ @ 2000. The big difference is not that you'll lose power; as you can see, the numbers are the same; but that you'll lose the possibility of reasonably priced improvement. With the carbed 460, put a better manifold on there, good 4-into-1 headers, a good 750 cfm carb, and a slightly more a ggressive cam and watch 230HP/390TQ power turn into 300HP/480TQ power for less than a grand. Do that to an EFI 460 without seriously modifying the computer's programming and spending serious money on custom programming sessions (could be up to $500 or more) and you'll be lucky if the computer will even bother to run the engine. And that's assuming you can even find that stuff for the EFI 460. Aftermarket support is weak, expensive, and not getting much stronger.
The Law
1989 F-250 HD 4x4
460, C6, BW 13-56, Sterling 10.25" (4.10:1), Dana 44 HD (4.09:1), twin K&N's, no muffler, stock lo-flo cat, Bosch Platinum Plugs (0.060") MSD 6A and TFI Blaster Coil
>may loose power
The Law
1989 F-250 HD 4x4
